First post, by galaxy76
i have a new binary bios for my music keyboard.
can i use HN27C4096HCC to replace original at27bv4096 (out of stock) on this music mother board?
AT27BV4096 = Dual power 4 Mbit OTP Eprom
Dual voltage range operation:
– Unregulated battery power range, 2.7V to 3.6V or standard +5V ±10% power range
HN27C4096HCC = 4 Mbit UV Eprom single +5V ± 10%
mother board pdf service manual :
https://we.tl/t-n6sFdAE9sJ
on PAG 13 is present at27bv4096.
Reply 2 of 9, by grey_beard
galaxy76 wrote on 2023-02-20, 08:22:
Well, that link doesn't work anymore.
As long as your board is running on 5V levels I'd say the hitachi should work as a substitute. It's has faster access speeds than the atmel, so that should be fine and the pinout seems to be identical too.
Reply 3 of 9, by Tiido
Pinouts are same so things will work as long as they contain same data.
Reply 4 of 9, by galaxy76
thanks, the motherboard is 3.3v.
in the attached photo extracted from the service manual you can see the power supply. i searched the at27bv4096
Reply 5 of 9, by galaxy76
grey_beard wrote on 2023-02-27, 18:34:
now the link is active
https://we.tl/t-69crZn19qG
Reply 6 of 9, by mkarcher
galaxy76 wrote on 2023-03-04, 06:53:
So the HN27C4096HCC is most likely not going to work, because it requires 5V supply voltage. Chips that work with 3.3V usually have the letter "V" (like "voltage") in their model number, as the AT27BV4096 does.
Reply 7 of 9, by galaxy76
mkarcher wrote on 2023-03-04, 07:12:
I thank you. do you know if there is another compatible chip?
Reply 8 of 9, by mkarcher
galaxy76 wrote on 2023-03-04, 13:12:
You need a PLCC44, 3.3V 256K x 16 EPROM (or pin compatible EEPROM or flash ROM). I searched using Google and some distributors, and I just found one other product of that type: The ST M27V402. Beware: Both the Atmel/Microchip chip and the ST chip are one-time programmable, and not erasable. If you purchase a used chip, it will be of no use. Make sure you get new old stock (or even new stock).
Reply 9 of 9, by galaxy76
mkarcher wrote on 2023-03-04, 18:47:
thanks! 👍
