First post, by Ryccardo
Very long shot but I was wondering if anyone's ever seen a PC case like this:
184.12 KiB
65.19 KiB
252.99 KiB
117.5 KiB
  • At the top right looking at it from the back there's an integrated door lock;
  • You open the left panel with a flip-up handle at the center-top that latches open;
  • The lower sticker on the back says Micronica, which was the manufacturing arm of then Italian giant Computer Discount, and Dex their store brand, unfortunately I don't know if the case was also in-house or a third party product;
  • The grey cap at the bottom front hides the front USB ports (which are wired with a funnily colored, untwisted, and unshielded cable);
  • The red-looking LED is just a barely deeper orange (and unconnected on both my computer and this one... funnily enough I've seen at least 3 boards that support a bicolor power LED but just blink green...)
Thanks in advance for even the wildest guess!
Reply 1 of 2, by PcBytes
Try removing the front panel if you have access to it. More often than not there should be a number or model of sorts printed on it. Based on that, I might be able to track down the manufacturer.
Reply 2 of 2, by Ryccardo
Unfortunately those are the only photos "available" online (after searching for "case pc dex -samsung", decoding Google's spy redirect result URL, and going to the wayback machine) - we threw away ours around 2009 and only saw one abandoned on the road maybe 7 years ago 🙁
