Reply 60 of 145, by Irinikus
- Oldbie
pshipkov wrote on 2023-03-25, 17:38:It is surprising how much V5 is holding back the interactive graphics. On this mobo+cpus, Q3 can be in the 200+ fps range with b […]
On this mobo+cpus, Q3 can be in the 200+ fps range with better video card.
But regardless of that, optics of the assembly are great - clean and tight.
Maybe put a “sock” on the molex cables to hide the yellow red black wires.
They stick out a bit from the otherwise uniform look.
Once I’ve got all the hardware I want in the build I’ll wire it up with individually wrapped cables, so the ones that I’m currently using to power the Voodoo5 will be removed!
I’m purposely using the Voodoo5 for this build, as I intend this build to be a showcase for this card! (It’s period specific to this hardware.)
The Voodoo5 may not have the best performance by a long way, but it’s a Voodoo5 and that makes it special! (The end of the line for 3dfx!)
When I eventually get around to building up a Pentium 4, then I’ll employ the best AGP card I can get my hands on!
