First post, by Jo22
Hello everyone,
Just found something interesting: It's a Windows 3.1 wave form driver for the AdLib Music Synthesizer Card.
Does anybody of you have experience with this one? I suppose it uses the YM3812 as a simple DAC, perhaps by playing with volume control.
Or maybe, I thought, it uses CSM.. Hence, I didn't try it out in emulation yet:
The speech of Xacalite in Silpheed didn't work out very well, as some of you may remember (it used an rarely used OPL1 feature). ;)
So if some of you have a 286 or higher PC with an AdLib card installed, please have a look it. :)
It also works with Windows 3.0 MME and can coexist with the AdLib MIDI driver..
Best regards,
Jo22
    ADLIBW.ZIP
    6.42 KiB
    83 downloads
    AdLib Waveform Driver for Windows 3.1 and Multimedia Windows
Reply 1 of 10, by n0p
Jo22 wrote on 2023-04-22, 23:02:
So if some of you have a 286 or higher PC with an AdLib card installed, please have a look it. 😀
Thanks! I can confirm this drivers works (and sound is very clear, really) in Windows 95 on Hand386
Reply 2 of 10, by Jo22
n0p wrote on 2023-08-06, 10:59:
Glad to hear! ^^ Thank you, too for testing! 😎 👍
Reply 3 of 10, by Cyberdyne
The quality is so good. Adlib is a no DMA sound blaster. Why was it not used more
Reply 4 of 10, by Grzyb
Cyberdyne wrote on 2023-08-06, 21:46:
Adlib as DAC is 6-bit, right?
So it's worse than non-DMA SB, or Covox.
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 5 of 10, by Tiido
6bit logarithmic per operator, but you won't be using several channels or ops to get more since the access is far too slow to make it work well enough to increase resolution. That 6bit log volume control is comparable to something between 4...5 bits linear DAC
Reply 6 of 10, by Grzyb
Isn't logarithmic supposed to provide better dynamic range than linear?
A-law and μ-law are based on that idea...
Reply 7 of 10, by Tiido
Here you one side of the waveform (because you play with the volume control and not the source sample itself in the YM chip) and not both sides around the zero point, so it really really hurts whan can be achieved. One half of the waveform you try to play has very low precision and other half has increasing precision toward the extremes where it doesn't need it, while stuff like A and µLaw have the precision near the zero point where it is most needed and begin to lose in as amplitude increases but where it no longer is necessary to have. I don't right now have access to my test data from older times when I was playing around with it, I could show exactly the problem and its effects.
Reply 8 of 10, by Scali
Tiido wrote on 2023-08-07, 17:48:
Yes, I vaguely recall that I once worked out that even a single channel can only play at about 30 kHz on an OPL2 because you couldn't send the commands faster.
Reply 9 of 10, by Tiido
In optimal case you can only reach the chips' own sample rate (which requires synchronity with the chip for best results) but to do any of the advanced stuff you need more than that and it is impossible even on the chips with much shorter access times like OPL3. (I have not tested OPL2 per se but I have worked with its relative OPLL, OPN, OPM chips and all of those can take a new byte every sample period when you don't set up index value)
