Reply 20 of 24, by analog_programmer
Falcosoft wrote on 2023-08-02, 10:32:
Yes, but the echoed messages sound like simple information, not like a warning ( I mean there is no emphasis on that you actual […]
Yes, but the echoed messages sound like simple information, not like a warning ( I mean there is no emphasis on that you actually have to use another ecw file for normal Midi operation).
The messages do not tell you that if you experience Midi playback problems it's because of the included DEFAULT.ECW.
As a compromise 😀 :
ECHO The default ECW wavetable file "DEFAULT.ECW" is a copy of "DOSTEST.ECW".
ECHO This means it contains only piano and no drum kits at all.
ECHO If you want to use Midi you should use another ECW wavetable file.
ECHO Find one and replace the default wavetable file "C:\SBA2ZS\DEFAULT.ECW" keeping the name "DEFAULT.ECW".
I'll change the message, which is related to limited default wavetable file, to this:
ECHO ATTENTION!!!
ECHO In order to work properly the driver needs EMM386 or another DOS memory manager!
ECHO.
ECHO This means that it only contains very limited MIDI instrument sets.
ECHO If you want to use more of MIDI capabilities of your SB Audigy 2 ZS in pure DOS,
ECHO you have to use another ECW wavetable file!
ECHO Find yourself a suitable ECW wavetable file (i.e. "EAPCI8M.ECW")
ECHO and replace the default wavetable file "C:\SBA2ZS\DEFAULT.ECW",
ECHO keeping the name "DEFAULT.ECW"!!!
ECHO.
ECHO REBOOT THE SYSTEM NOW TO LOAD THE DRIVER!!!
ECHO.
ECHO You can then check the audio with "C:\SBA2ZS\SBEGO.EXE".
What do you think about that? Is it clear enough?
P.S. Silence is sign for acceptance.
Here is the link to the new files with updated warning messages in installer batch-script:
https://www.sendspace.com/filegroup/c%2BVCHOC … C7Zec%2BTUf99lU
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
Reply 21 of 24, by Falcosoft
analog_programmer wrote on 2023-08-02, 14:05:
I'll change the message, which is related to limited default wavetable file, to this: […]
As a compromise 😀 :
ECHO ATTENTION!!!
ECHO.
ECHO.
ECHO.
Yes, I think it's more than OK 😀
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 22 of 24, by Intel486dx33
I am still Rockin my Audigy 2ZS in my “HP z440 workstation”.
I can’t seem to get rid of this card.
It has served me great for many years since Win98
I think this is the Last Fastest Modern Computer that will support it.
It’s not easy finding computers with PCI slots anymore.
My Specs
HP z440
Xeon 1660v4 ( 8-cores, 16-threads )
64gb DDR4 2133p ECC REG. RAM
Nvidia 3060ti
Sound cards - Creative X3 USB and Audigy 2ZS
    420.42 KiB
    738.39 KiB
Reply 23 of 24, by analog_programmer
Intel486dx33 wrote on 2023-08-07, 08:07:
I am still Rock-in my Audigy 2ZS in my “HP z440 workstation”. I can’t seem to get rid of this card. It has served me great for […]
My Specs
HP z440
Nvidia 3060ti
Very nice machine for such a soundcard 😀
For about 17 years I have an SB X-Fi Fatal1ty FPS with very similar front panel and I still use it in my old desktop "daily driver" machine (Phenom II x6 1055T, 8GB DDR2-1000, Asus M4A79 Deluxe - yeah, I know it's old, but still do its job). I've once tested my X-Fi soundcard with adapter and cable from PCI to PCIE x1 slot and it turned out that it works with no problems. I think that the Audigy 2 ZS cards will work the same way with newer motherboards without PCI slots, but I haven't tested yet my resurrected card with PCI-PCIE adapter.
