Reply 20 of 243, by The Serpent Rider
- l33t++
Irinikus wrote on 2023-07-06, 15:23:It will be very interesting to see how the bottlenecking affects the performance of the GTX 690 in this system. (The SLI setup may render the system very jerky (Due to micro stutter), but I won't know until I try it!)
Stuttering is caused by heavy GPU load in multi-card AFR setups, because cards can't sync their workload. Slow PCIe affects it minimally. You'll have CPU stuttering though, because Socket 604 is mostly Netburst, with all following drawbacks.
