First post, by dreamblaster
Hi
I am working on a new project : Triple McDigit
It is a CPU speed display for your 3.5" drive panel, that shows your Normal and Turbo speed, synced to your mainboard turbo status.
Feature ideas :
- CPU speed is editable by keypress combo, setting is stored in EEPROM. There is a speed value for Normal and Turbo mode.
- CPU speed can be set with 3 digits and dot, or can be set to alphanumeric 'Hi' and 'Lo'.
- The large button can operate as turbo switch, when the Triple McDigit Display is connected to your mainboard and to the turbo led.
Todo :
- make it all work (software/hardware - debugging basics of the first prototype now)
- maybe choose a better name for the project
Still under development, not working yet, i will post progress in this thread.
30.12 KiB
37.12 KiB
Thanks for your support !
