First post, by un1xl0ser
I purchased this Unisys server during the pandemic and trying to push it to its limits. I would blame Halt and Catch Fire. It was small and had a SCSI interface and a 8 UART serial card. When I booted it up, it ran SCO Unixware with two drives that were very, very loud. I was planning on rooting the box and playing around with it, but I've already done a lot of Unix systems and a 486 is a bit limiting compared to what I am used to.
I upgraded the CPU to a DX66, as the BIOS boot screen shows support for it. I haven't been able to get it to clock over 40Mhz, but it is very stable. The RAM has been maxed out to 64 MiB. I preferred to use the SCSI to boot, but that has me limited to 1GB. I have made many attempts to get a drive > 1GB and the BIOS won't do it. Even IDE with a real card and BIOS is not stable over 1GB with spinning disk or solid-state with adapters. This includes attempts at SCSI2SD. What is stable is using the first 1GB of an 8GB SCSI drive. It is a 68pin drive (Seagate Cheetah) with an adapter. I have a PleXwriter 12/4/32, also attached via SCSI.
ISA cards installed are:
3Com Etherlink III
ATI Mach64 2MB
Sound Blaster CT1470 Vibra PNP
Partitioned the 1GB that can be used stably into 200M and 800M. It has the OS/2 boot-loader and DOS 6.22 with WFW, however it is not well configured. I have OS/2 Warp Connect 3.0 (Blue Spine) installed and stable. ATI Mach 64 2.2 drivers installed, as are the SoundBlaster drivers for PNP. I will probably put in an ESS card once I find it. I think I can do better for an audio card, but was having some issues with compatability and this one worked.
Will take better pictures and screen-shots later, if there is any interest. I have not gotten it online or on a network yet, and I have not yet had a chance to RTFM or browse the guides on Fixpacks.
Reply 2 of 17, by un1xl0ser
Disruptor wrote on 2023-07-04, 21:07:
What kind of SCSI adapter or chip does it use?
Integrated SCSI (Adaptec ASW-B626 - chip Adaptec AIC-6260AL)
This is actually the best reference on the built-in chipsets.
https://mastodonpc.tripod.com/personal/4253.html
Reply 3 of 17, by Disruptor
Seems like you need ASPI2DOS.SYS
mkarcher and me never have checked controllers like the AHA151x or AHA152x for large disks - like he did with 274x and 284x and ASPI7DOS.SYS
Reply 4 of 17, by un1xl0ser
Disruptor wrote on 2023-07-04, 22:17:
I am booting off of the drive, so with ASPI2DOS.SYS and the appropriate DISK.SYS it says that the disk is under BIOS control. At least that is on DOS 6.22. I haven't dried putting a secondary SCSI drive on there to see, mostly because there isn't space inside the case for it. If I am feeling froggy I will get a SCSI2SD set-up to see if disks loaded after that have < 1GB workable. That may able to be in there, and can at least get it working.
One of the reasons for using SCSI is I was hoping to not have to deal with legacy IDE limits.
Warp seems to have drivers for it, but I haven't tried any advanced partitioning software. My hope was to get the kernel as up-to-date as possible, I think with the Warp 4.5 kernel was back-ported in a Fixpack. I also haven't looked much into the Warp config.sys.
Reply 5 of 17, by Disruptor
Perhaps you can try whether the limitations just apply to the boot drive - try to connect a second drive then (for testing purpose: first try a 4,5 GB drive, then 9 GB or larger).
Probably your WARP driver doesn't have those limitations.
Reply 6 of 17, by un1xl0ser
Disruptor wrote on 2023-07-04, 22:32:
Warp 3.0 Connect will recognize the full disk, but is not stable to install or partition over 1GB. It will throw disk errors when trying to install. I've tried with and without the boot loader. At the moment I delete all partitions with a Windows 98 boot disk, then do partitioning of a clean disk with OS/2 at > 1024M and it works fine. FWIW, I would hope the Windows 98 disk would support the max, but it doesn't see it as being larger than 1024M.
Will try with a second disk once I get SCSI2SD or something similar working. I think I can fit that inside the case without an issue.
Reply 7 of 17, by weedeewee
FYI, an alternative to scsi2sd is zuluscsi
Do not ask Why !
Reply 8 of 17, by un1xl0ser
weedeewee wrote on 2023-07-04, 22:44:
That's what I may try next. My SCSI2SD was an older version, and with the firmware updated it was unstable. Drives configuration would vanish whenever the SD card was removed. Problem could have been between computer and chair. I think that considering the form-factor and space involved, I may use the Centronix connector and go with that form-factor for disk expansion.
It's also "enough" disk, but I would love something that could allow for solid large-file transfer that doesn't involve splitting files onto virtual floppies, or burning physical CDs.
Reply 9 of 17, by Disruptor
un1xl0ser wrote on 2023-07-04, 22:40:
I guess the problem is the BIOS support.
If it has problems with partitions over 1 GB it will be more likely that systems that rely on BIOS support (like Win98' DOS portion) will have a problem. So I recommend to create all partitions for DOS (FAT16) to be completely within first 1 GB - data exchange 😉. For a Win98 FAT32 partition you may try to place it that the first sectors are within first 1 GB; if you do not boot from it it may pass the border. The HPFS partition may be completely after first GB.
Perhaps you can extract the controller BIOS or even update it. Perhaps you'll get access to disks > 1 GB or even INT13E support.
Ye, SCSI2SD is a nice thing but seems to be too slow when used in Versions below 6 where it hits almost 10 MB/s. And the mentioned zuluscsi also lacks of Ultra, LVD or Wide support.
Reply 10 of 17, by Disruptor
Your controller has an AIC-6260AL, my controller has an AIC-6370Q
My 1520B BIOS neither supports disks > 8 GB with BIOS 1.15 but > 1 GB is no problem.
The required ASPI2DOS.SYS in its newest version 3.68 supports 6260, 6360, 6370. It also does not support disks > 8 GB.
The 32 bit driver from Windows 95 B makes no difference.
So you may have a chance at least to get disks < 8 GB but > 1 GB working.
You may try to boot DOS from a floppy and run FDISK and tell me what size it reports. Perhaps you can run SPEEDSYS 4.78 too and tell me which CHS translation it reports for a disk > 1 GB and < 8 GB.
Then try the same with ASPI2DOS.SYS loaded (ASPI2DOS should report that it routes INT13 through ASPI driver).
So we can see if perhaps the controller BIOS is the problem...
Perhaps you can dump it with debug.
First you have to find the location of the BIOS. when you dump with d you quickly will see Adaptec strings. Try to start from c800:0, and increment in 16k steps: cc00:0, d000:0, d400:0 and so on
When you have found it, continue with the further strings.
Run from DOS prompt:
debug
dc800:0
rcx
4000
n adaptec.rom
wc800:0
q
Reply 11 of 17, by Horun
I have a few items with the AIC-6260AL (two motherboards and a 1520 plain) and none of them support larger than 1GB HDD iirc.
One of the motherboards is similar to OP but is a Unisys PW 300/486 25-50, it has built in IDE also.
Attached the bios just for reference, the scsi bios part is (hex read): Adaptec ASW-B626 BIOS...Version 1.0. AHA-1520 1990 Version 1.02.
I added the jumpers sheet and picture from 1994 here: http://www.vogonsdrivers.com/getfile.php?fileid=1582
Reply 12 of 17, by Disruptor
Horun wrote on 2023-07-07, 00:45:
Looks like a 64 KB All-in-one Phoenix BIOS. No extra SCSI BIOS.
Reply 13 of 17, by Horun
Yes it is an All in One with WD90c11 video, main 486 board and adaptec 1520 bios all wrapped together.....
Reply 14 of 17, by un1xl0ser
Disruptor wrote on 2023-07-05, 20:32:
So we can see if perhaps the controller BIOS is the problem... Perhaps you can dump it with debug. First you have to find the lo […]
Adaptec ASW-B626 S2 BIOS
Version 1.0
Copyright 1991 Adaptec, Inc.
All Rights Reserved
The provenance of the drivers is Adaptec EZ SCSI 5.0c for DOS / Windows 3.1. ASPI2DOS.SYS is version 3.86 from the attached screen-shots.
Reply 15 of 17, by un1xl0ser
I created 2 x 4GB drives with BlueSCSI, made them targets 1 and 2. They are recognized fine. They have been low-level formatted with SCSIFMT and passed validation to the full 4GB.
It says no logical drives though, and the DOS 6.22 FDISK seems lame, or I am missing switches. Will be spending more time to RTFM, but if anyone has any pointers, it would be appreciated.
    373.77 KiB
    Screenshot of new drives.
Reply 16 of 17, by un1xl0ser
So I still have something to learn about DOS and partitioning multiple disks. I'm still going to try to figure out the right way of doing this. I'm also going to dig out some utilities that I had that showed the CHS and other details of the disks especially the virtual ones.
In OS/2 WARP 3.0 with XR_W040 applied, I am able to select the different disks and do partitioning. The aforementioned controller works fine with a 4GB disk and a single partition with HPFS. I tried to create a 2G and 1G partition formatted with FAT, but ran into a cylinder limitation of 1023 for FAT (at least as far as OS2 disk). I was able to make a 512M and partition it, but rather actually figure out the geometry that BlueSCSI is reporting.
So the controller will support 4GiB drives, and I will push the limits on OS/2 and test if everything is accessible/stable. I'm hoping to be able to get a pair of 16G drives working under OS2 and being able to keep a collection of low-end DOS and Windows games on the system.
Reply 17 of 17, by Disruptor
Ye, in my standard partition scheme for retro computers I place my legacy partitions to end no later than at cylinder 1021.
Using my larger disks I use this rule:
My FAT32 Windows 98 SE partitions start at cylinder 1022 (not at 1023, because some BIOSes report 1022 as last cylinder instead of 1023 - DOS' FDISK shows 8025 MB instead of 8033 MB then).
If you can place the start of your OS/2 boot partition at cylinder 1022 or before, you may try to go beyond that limit with that HPFS partition. Does it work?
