dgVodooo 2.8.x and related WIP versions
Reply 180 of 204, by mitradis
ELK wrote on 2025-07-10, 19:17:
you can make a batch file
perhaps you right. Batch file give more features for this.
Reply 181 of 204, by myne
You can do it in a normal shortcut.
You just have to put "start /affinity 0x1 exename"
I put 0x1, because its hex. if you want to use any other single core, options should be 2,4,8,16,32 etc for one core.
ie, the hex is a binary number with each bit representing one core. The first 2 cores should be "0x3"
I built:
Reply 182 of 204, by lowenz
lowenz wrote on 2025-02-23, 16:26:
Forced MSAA can't work well with an HDR output (I'm testing on a HDR10 monitor) using Color Space > ARGB 8888......is there a solution or it's just inevitable (being the MSAA designed around 8888 color space)?
Up, isn't possible to use forced MSAA and ARGB2101010 (for HDR10 output)?
Reply 183 of 204, by Deffnator
After the last few tests with Mech 2 mercs over the last 4 days
Things i noticed here that Been_Nath should had noticed too
-Titanium uses 3dfx glide API DLL's while the main menu uses ddraw due to its direct3d rendering option, also there are memory timeout problems with mercs titanium that i noticed where the game suddenly loses the ui and graphics glitches with a -1 memory error ingame that pop up when pressing esc but only by alt+tab you see the message for an instant when using 3dfx, directdraw/direct3d may suffer from this too.
-Every Mech2Mercs version that isnt titanium still uses Ddraw.dll as direct3d that includes even the 3dfx release and other 3d enhancement versions, something mech2.org and pcgw covered it last year https://www.pcgamingwiki.com/wiki/MechWarrior … es#cite_note-11 So it is a issue i wish dege checks out once he has free time, since it covers both the game and graphical settings like software and Direct3d.
-Under Titanium all of the rainbow UI problems mech2 3dfx has are missing from it when using 3dfx, the game works fine and dandy outside the mentioned random memory issue, Main Menu still uses ddraw.dll due to also using direct3d, and it suffers from scaling issues which aren't present on mech 2 and GBL due to said games always being locked to 640x480 windowed and mercs +titanium always forcing fullscreen window like UT'99 does, though some of the erratic menu behavior can be atributed to dxwnd i believe, but that is relegated to the main mechwarrior 2 thread at The Guide/Windows.
This what i could gather til now, the dxwnd stuff i will mention at the mech 2 thread.
Reply 184 of 204, by Manekite
In Runaway: A Twist of Fate cursor never changes with dgvoodoo, it supposed to based on context like in majority of adventure games.
Also, about track selection in TOCA 97, I think at some point everyone kinda agreed that it was supposed to look bugged like it does right now, so I decided to check how it runs natively and actually you can see track previews pretty clearly this way.
It's how it runs without any wrappers at all, only couple shims to get it running, same as CMRally has, cause it's the same engine I guess.
Reply 185 of 204, by Deffnator
Just to inform that i booted up tachyon after a long time with the newest wip, plus i followed Dege's tip to increase space.exe stack to 1mb+ and now i am playing tachyon not only with reshade but also with better stability under windows 10 with CRT Aspect radio enabled.
As for Mechwarrior 3, on which i haven't reported in a while, the game suffers from ghosting cursor issues, but it isn't gamebreaking.
I haven't checked under nGlide yet to see if the bug persists there, i'll give a try later this week.
The attachment Mech3fixup 2025-09-21 23-37-50_341.jpg is no longer available
also i tested with and without reshade and the ghost cursor issue persists
Reply 186 of 204, by lowenz
Oh damn, seeing the mechlab of Mech3 after all these years.... 😁
Reply 187 of 204, by Deffnator
lowenz wrote on 2025-09-23, 08:22:
Lemme also give you an extra after discovering today and i hope dege once he comes back from his work free time, checks out.
The attachment Bzone_32 2025-09-23 17-59-53_086.jpg is no longer available
The attachment Bzone_32 2025-09-23 17-58-46_235.jpg is no longer available
The attachment Bzone_32 2025-09-23 17-56-43_431.jpg is no longer available
The attachment Bzone_32 2025-09-23 17-56-32_231.jpg is no longer available
Reply 188 of 204, by lowenz
Battlezone 😄
Reply 189 of 204, by p0werb1t
ELK wrote on 2025-07-10, 19:33:
Lemonzest wrote on 2025-07-10, 07:21:
Getting 404 when trying to download the latest and previous builds from both the forum thread and the homepage
I could email 2.86.1, 2.85, or 2.84.1 . For some reason 2.86.2 is popping up for a tojan virus, while 2.86.1 is not. The dgVoodooCpl.exe are identical in size down to the byte but are giving back different checksums meaning that the files are different. Very, very, very strange. (on top of the website acting up)
I won't send you 2.86.2 as it's coming up as a virus. 2.86.1 isn't but I'm still not confident it's not a virus, and 2.85 is a different size. However these were all downloaded today or yesterday, and dege hasn't replied about this so his website might actually be hacked right now. I downloaded 2.84.1 on 1/15/2025 and I'm highly confident it isn't infected, and if you do want me to email you one I highly suggest you just choose this one.
For the dgVoodooCpl.exe 2.86.2 problem, we can use the same file (and same version) from the previous WIP98 (is newer than 2.86.1) that don't trigger AV.
Reply 190 of 204, by Dege
I've just released a small patch version for 2.86
v2.86.4
  • Fixing the 'failed dynamic index buffer Lock' bug in D3D8/9 coming with modern D3D12 drivers on Win11
  • Fixing a bug for the sake of the Win11 SDK D3D12 Debug layer (it is not a bug actually but the debug layer undervalidates the thing in question)
  • Fixing a D3D12 interface leak
  • Determining the refresh rate of the current desktop display mode always failed, fixed (D3D11/12)
  • Removing YUV texture support from D3D8/9 in general (Wallace & Gromit in Zoo Project)
  • Fixing a silent error in the D3D8/9 frontend (BC Kings)
  • Fixing a frontend D3D8 bug (Roland Garros French Open/Next Generation Tennis 2002)
  • A threading fix for D3D12 if the CPU is built with a hybrid architecture of P- and E-cores (Win11)
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_86_4.zip
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_86_4_dbg.zip
It should not trigger antiviruses. Only 1-3 of them false-detects it on VirusTotal and even Win Defender/SmartScreen does not complain about it (surprise) for me.
I will look at the reported problems, there are a lot and lot of them, but I wanted to fix things first that I encountered on my new machine and I didn't have much time for dgVoodoo anyway.
Btw, I think I'll have to re-install all of the games (on-demand) that I tested dgVoodoo with. It's another factor slowing me down.
Edit: I reuploaded this release with a small threading fix for hybrid CPU architectures.
Reply 191 of 204, by lowenz
Splinter Cell Conviction does work in D3D12 but not in D3D11 😐
As it works with no wrapping.
"Luna Park" intro
native intel d3d9 ~ 60 FPS
dgv2 D3D12 fast video memory access ON ~ 45 FPS
dgv2 D3D11 fast video memory access ON (or OFF, it dosn't matter) -> crash @launch
Intel A380, lastest drivers suite.
Reply 192 of 204, by lowenz
About no specific game, D3D12 still has problem with Special K.
No problem with D3D11.
Reply 193 of 204, by Glurak
Beyond Divinity has Hardcore Flickering when entering the game after the start menu. And using Windowed Scaling FHD ISF (tryed other scaling same problem)
Reply 194 of 204, by Deffnator
Dege, Sid Meier's Gettysburg and Antietam resolution aren't scaling with dgvoodoo.
Also, Apache Longbow 3dfx update 2 and Hind 3dfx has flickering cursor issues
Reply 195 of 204, by Squall Leonhart
Deffnator wrote on 2025-12-24, 04:04:
They don't use directx or glide for rendering.
Reply 196 of 204, by Deffnator
Squall Leonhart wrote on 2025-12-25, 04:39:
the game uses ddraw, i got to test with all wrappers avaliable with cnc-ddraw having a somewhat "success" but the game is forced into a windowed mode.
dege fixing this game would do wonders
Reply 198 of 204, by Dege
For the time being, I've just released a small patch version for 2.86 again:
v2.86.5
  • Fixing a clipping problem in D3D9 (Beyond Divinity)
  • The device/vendor info returned for virtual cards is reworked (Fallout New Vegas, ...)
  • Fixing an issue causing CPU performance loss in the D3D12 backends in certain cases (Fallout NV, ...)
  • Fixing bugs in the deframer and mipmapper of the image presenters (larger than max resolutions)
  • An exponent of 1.3 is used for default exponential Glide gamma ramp (if Glide gamma ramp is enabled)
https://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_86_5.zip
https://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_86_5_dbg.zip
Only 1 antivirus flags it as malware on VirusTotal.
Reply 199 of 204, by lowenz
Thanks as always and have a good 2026!
