Reply 1220 of 1558, by sharangad
- Oldbie
robertmo3 wrote on 2024-05-03, 08:03:my is HD2500
Do you have an SSD?
https://www.youtube.com/@sharangadayananda
Do you have an SSD?
sharangad wrote on 2024-05-03, 08:08:robertmo3 wrote on 2024-05-03, 08:03:my is HD2500
Do you have an SSD?
My old i7 has an HDD and the uhd 620 has a slow SSD (slow write speeds).
sharangad wrote on 2024-05-03, 08:10:sharangad wrote on 2024-05-03, 08:08:robertmo3 wrote on 2024-05-03, 08:03:my is HD2500
Do you have an SSD?
My Dev machine and the hd4000 have fast sata SSD s
That might be the cause of it. Unknown command buffer elements are logged. That might be why it crashes.
It shouldn't affect it. Will test that in a bit.
hd2500 is not hd2000
https://en.wikipedia.org/wiki/List_of_Intel_g … rocessing_units
ogl4 vs 3.1
robertmo3 wrote on 2024-05-03, 08:26:hd2500 is not hd2000
ogl4 vs 3.1
UHD620 is ogl 4 as well and it doesn't work there either. SIngle frame.
try spd3d.uc from tomb raider rendbeta4
robertmo3 wrote on 2024-05-03, 08:51:try spd3d.uc from tomb raider rendbeta4
Will do.
It wasn't the logging. Named pipe comms do produce gibberish on the Sandy Bridge based machine and I don't know why. It happens randomly on my dev machine as well.
How? RReady doesn't use teh spd3d.uc file.
but the game does
robertmo3 wrote on 2024-05-03, 08:59:but the game does
Ooh! Particle effects and smoke.
sharangad wrote on 2024-05-03, 09:14:robertmo3 wrote on 2024-05-03, 08:59:but the game does
My bad, the particles were already there. Is there something specific I need to see with beta4?
no that was actually a mistake on my side 😉
i mean i have cart racing working on 2 cores slowed down to 1,5GHz with integrated graphics (no idea why it didn't work before)
(i thought that was cause of different .uc but it wasn't)
i think it didn't cause i was using the tr .uc 😉
it looks the problem to test cart racing is you have to press alt-tab to refocus and we know alt is buggy
cart racing only works fast for me (with 2 cores and integrated graphics) when i have focus set to dosbox-rendition while fullscreen plays in the background.
when i refocus to fullscreen it is slow again
i made cart racing work on 2 cores by setting priority to dosbox to higher
[sdl]
priority = higher,higher
