Reply 1060 of 1540, by sharangad
- Oldbie
Does anyone know if the Rendition enhanced tracks had issues on original hardware?
https://www.youtube.com/@sharangadayananda
The socket comms lag might just be because vs 2022 taking ridiculous amounts of cpu idling.
how about this
https://www.msys2.org/
the easiest way to tell if fog responsible is to turn off fog
robertmo3 wrote on 2024-04-18, 16:44:the easiest way to tell if fog responsible is to turn off fog
If I force fog on permanently it renders correctly. The in game views do, but the replays are blacked (fogged) out.
robertmo3 wrote on 2024-04-18, 14:45:how about this
If I build with that, I think it'll need msys2 to run. I might have better luck with gcc for Windows that runs without msys2.
Vs2022 has become a cpu hog since theprevious patch Tuesday update. It was fine before that. I don't know for a fact that it's Vs2022 causing problems.
you don't need msys2 to run.
You only need .dlls
dlls are here c:\msys64\mingw64\bin\
sharangad wrote on 2024-04-18, 14:21:The socket comms lag might just be because vs 2022 taking ridiculous amounts of cpu idling.
Nope, happens even without it.
sharangad wrote on 2024-04-19, 05:59:sharangad wrote on 2024-04-18, 14:21:The socket comms lag might just be because vs 2022 taking ridiculous amounts of cpu idling.
I think I've fixed it. Timing error at startup and repeating keys (keyboard repeat).
[EDIT] Yes I have[/EDIT]
Tomb Raider 1 Rendition Edition:
(Sorry, you're going to be disappointed). @Raven-05 is this supposed to be Lara's passport spinning around?
That's all the objects on the menu constantly spinning, so yeah the passport is in there somewhere. It definitely isn't supposed to be doing that unless you're holding down the left/right button the whole time.
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | SB Pro 2 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Agent of the BSoD wrote on 2024-04-20, 01:05:That's all the objects on the menu constantly spinning, so yeah the passport is in there somewhere. It definitely isn't supposed to be doing that unless you're holding down the left/right button the whole time.
Thanks @Agent.
I don't have it installed anymore but I think dosbox does that if you have a joystick plugged in. You need to disable the joystick in the dosbox config or something like that. I think when it's spinning, if you hold left or right on the keyboard it stops spinning.
chuky wrote on 2024-04-20, 01:25:I don't have it installed anymore but I think dosbox does that if you have a joystick plugged in. You need to disable the joystick in the dosbox config or something like that. I think when it's spinning, if you hold left or right on the keyboard it stops spinning.
Thanks for that. I did try holding down the arrow keys but it didn't seem to do anything. Maybe dosbox /rready didn't send the keystroke through.
have you tried unplugging joystick?
robertmo3 wrote on 2024-04-20, 04:15:have you tried unplugging joystick?
Will try that next, when I'm back on the job.
Yup disconnecting the pad worked a treat:
There's no sound for some reason.
[EDIT] Apologies for boring videos. I just get a kick out of seeing it.
Someone with a Rendition board, try running this from Windows and dump the output here:
https://1drv.ms/u/s!As-dKk-N73dSmG1vQYeiAvRdBuMw?e=b3NTPk
MD5: a5c11401bdfcb89c40f1fc76f91573e9
Buffer dims 640x480 stride 81 and linebytes 1280
Buffer dims 800x600 stride 81 and linebytes 1280
Buffer dims 1024x768 stride 81 and linebytes 1280
Buffer dims 1280x1024 stride 81 and linebytes 1280
