Reply 1140 of 1700, by sharangad
robertmo3 wrote on 2024-04-27, 10:43:
i don't care about rebelmoon.exe -vga
but rebelmoon.exe doesn't work too in rendition mode 😉
ef2000 complains about missing vesa support
Rebelmoon does work. You might need a newer build.
https://www.youtube.com/@sharangadayananda
Reply 1141 of 1700, by sharangad
Eurofigher needs a patch. There's no Speedy3D microcode file there.
Reply 1145 of 1700, by RaVeN-05
oh wooow, i have no words , rebel moon =0 , the Whiplash (Fatal Racing alt) you know what? there is no high resolution way to play Whiplash, now its available by RReady =0 omg
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 1147 of 1700, by RaVeN-05
robertmo3 wrote on 2024-04-27, 12:59:
you can play Whiplash in dosbox with voodoo emu patch in whatever resolution you want.
can you check if rebel moon with rebel moon rising folders work on real card?
hahah NO! ) demonstrate it! Whiplash 3dfx is statically linked and closest thing is dosbox-x with Glide emulation trough OpenGL libraries, but its limited to original resolution.
Reply 1149 of 1700, by sharangad
Whiplash has frame sync issues. Tweaked the FIFO path to be much much faster. In ICR2 with FIFO [ALT]+[X] produces in game framerates of 300 fps (with an RReady rate of 30 (with vsync)).
So the FIFO command synchronisation doesn't work, yet. But soon. I'll do another release tomorrow, sometime in the afternoon.
@Raven-05 do you know what the difference is between Whiplash and Fatal Racing? Does FR need a patch? The vanilla RenWhip+microcode+ batch files produces missing file errors.
Reply 1150 of 1700, by RaVeN-05
robertmo3 wrote on 2024-04-27, 13:47:
at least the intro runs 😀
the game itself doesn't indeed
ok how to do that?
details.
About Whiplash you need US Whiplash ISO and patch applied to it.
Whiplash US patch will not work on Fatal Racing EU
Reply 1152 of 1700, by sharangad
Whiplash:
https://youtu.be/YI8e5rW8frY
The chroma keying has been turned up too high. Will fix it before the next build and video.
Reply 1153 of 1700, by sharangad
I fixed the VESA problem with EF2000.
Now I get 4gw: couldn't map physical address
Reply 1154 of 1700, by sharangad
sharangad wrote on 2024-04-27, 22:44:
Nm that was a VESA linear framebuffer address not being returned. Now I get MIDI music with a black screen.
None of the other games needed a VESA 2.0 LFB.
Reply 1155 of 1700, by robertmo3
you should be able to enter the game now i guess
just move your mouse to top left corner of the screen and move it from up to down and back moving mouse slightly right after every pass (clicking all the time)
when you hear a click move the mouse to the bottom left corner and move from left to right and back moving mouse slightly up every time (clicking all the time)
when you hear a click game should start loading
(you have to stop the mouse for every click)
Reply 1156 of 1700, by sharangad
robertmo3 wrote on 2024-04-28, 05:54:
you should be able to enter the game now i guess just move your mouse to top left corner of the screen and move it from up to do […]
Pressing Escape produces a confirmation sound and it's sometimes possible to quit that way with a black screen.
I'll try your mouse trick.
Reply 1158 of 1700, by sharangad
Bit difficult to do and I don't know whether I did it right, but nothing happened.
Reply 1159 of 1700, by robertmo3
hitting enter twice is way easier and it is always right 😉
you should get confirmation sound every time if you succeed 😉
maybe wait a bit before each hit so that game has time to load second menu
using mouse doesn't guarantee you hit the right button
