Reply 1720 of 2967, by robertmo3
you can make HUD blink again with F6/F7 keys 😀
Reply 1722 of 2967, by robertmo3
robertmo3 wrote on 2024-05-07, 16:50:
as for rebel moon rising
there is no key for starting jetpack in rebel moon so i guess at some point some level might be not finishable 😉
or at least that feature will be inaccessible 😉
found jetpack key "F" in the read.me in both games: rebel moon verite and in rebel moon cgl
so i guess you just cannot assign it to some other key in settings, but it should work. Just don't assign anything to "F" key 😀
Reply 1723 of 2967, by sharangad
robertmo3 wrote on 2024-06-09, 13:57:
Oh wow! Didn't know the first game had a jetpack.
https://www.youtube.com/@sharangadayananda
Reply 1725 of 2967, by robertmo3
I guess someone with a verite board may check that.
In -vga mode it looks like it is changing resolution.
Reply 1726 of 2967, by sharangad
robertmo3 wrote on 2024-06-10, 16:22:
There's also some corruption at the bottom of the screen. I sometimes get missing texture and audio file errors not sure if it's wrapper related. Also can't seem to get the cgl version to run with the Verité binary. Missing texture error.
Reply 1728 of 2967, by sharangad
robertmo3 wrote on 2024-06-10, 17:34:
sharangad wrote on 2024-06-10, 17:07:
i already told you, you have to use files from here:
Re: RReady (Rendition Verite wrapper) Test Build (Alpha 1)
Ah ok. Forgot all about the textures.
Reply 1729 of 2967, by RaVeN-05
CGL is other API maybe high level on top of verite/glint or maybe its own low level. There is possibility to force rebel moon to load only in verite mode on Creative 3D Blaster PCI, by removing verit*.cgl files inside of game directory. the CGL API is not so well documented, and vogons community collected everything so far to assemble API SDK from pieces .
Fun with CGL (Creative Graphics Library) on 3D Blaster
I hope its have possibilities to trick CGL to run on non creative cards.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 1730 of 2967, by sharangad
RaVeN-05 wrote on 2024-06-11, 15:54:
Sounds like fun, once I get Speedy3d in shape. I'll take a stab at it as a side project maybe concurrently with speedy3d. That's how rready was built and I might learn more about speedy3d by doing that.
Speedy needs a lot more work.
Nice to see you back on this forum again.
Also is anyone interested in a store release with alpha speedy3d support? At some point I'll have to test the RRedline apps to make sure nothing's broken. I'm in fact curious to see if everything still works. It's going to take me a long time to test everything because the app/demo list is growing.
Speedy3D dma problem's still there it can be fixed for icr2 with either threadsafe=true or cacheddma=true. This only works for icr2 though. Nascars(sic) and eurofighter are out of luck.
I found a bug with dobox's dma register implementation and fixed it. But the instability is still there.
[edit] my posts are sounding a little robotic. Sorry.
Reply 1731 of 2967, by sharangad
Does Descent 2 run in DMA mode on real hardware?
Reply 1732 of 2967, by sharangad
Word of warning, the latest live build of dosbox is being detected as malware.
[EDIT] If the next live release gets flagged, I'll report it as a false positive to microsoft.
Reply 1733 of 2967, by sharangad
Hi
I'm working on adding vQuake support to RReady and have both overcome one obstacle and hit another .
Could someone with a Verité board run this and post the resulting FIFO.txt file. It may take a while (copy all 3 files and run run.bat).
https://nirvtek.com/downloads/Fifo.20240614.002.zip
MD5: 337aa329b4b16c03e8f48fc752054ce6
The problem I resolved was an INT1A call which needed a 32-bit protected mode dispatch routine and the one I hit was vQuake querying a ridiculous number of probably non-existent modes.
This build *should* (fingers crossed) return the BIOS strings correctly as well as well as the BIOS responses to the strange mode queries.
(Cross-posted to Rendition Verité thread).
The modes it's querying could be z-buffered versions of vesa modes
Reply 1734 of 2967, by sharangad
And now possibly this:
[EDIT]
This
https://nirvtek.com/downloads/Fifo.20240616.003.zip
MD5: b600fe0c6b98ae1faa358313eb574d95
not
https://nirvtek.com/downloads/Fifo.20240616.002.zip
MD5: 1beade1f8250bc0421ea0efe3e012de9
[/EDIT]
Sorry people I've PMd, my messages are stuck in the outbox and not going out.
Reply 1735 of 2967, by robertmo3
pressing + or - crushes rebel moon
also if you load the lev 6 switch save it crushes if you drop down the well behind you (you have to look at floor)
(in -vga it has solid blue color on the floor in the well)
Reply 1736 of 2967, by sharangad
robertmo3 wrote on 2024-06-16, 10:29:
pressing + or - crushes rebel moon ------------ also if you load the lev 6 switch save it crushes if you drop down the well behi […]
What do '+' and '-' do?
[EDIT] I'm in the middle of something else at the mo, will test it soon.
Reply 1737 of 2967, by robertmo3
in -vga they adjust screen side
Reply 1738 of 2967, by sharangad
The crash doesn't occur if you start a new game and then load level 6 switch, but yes it does if you load it right after startup. With Dosbox-Rendition the floor is a tiled texture, unless it doesn't crash.
I've had some other stability issues with RB. Starting a new game and playing randomly crashes the game within dosbox. I don't remember it doing this with older builds, but the again I've not played through the first level every single time I've done a build.
The game crashes within DOSbox with a dos4gw error.
[EDIT] It's the same with '+' and '-' (divide by 0).
On youtube:
https://youtu.be/jfh0RGlWWTM
Reply 1739 of 2967, by robertmo3
if you press F6 then + and - is not crushing
