Reply 880 of 1705, by RaVeN-05
If you press alt+m or alt+x you should see fps, but game will go into timedemo mode, much faster
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 881 of 1705, by sharangad
Everything fixed:
https://youtu.be/SeWK1FGp_e8
Could someone with an actual Verite board comment on the audio sync. I think the video is lagging here.
https://www.youtube.com/@sharangadayananda
Reply 882 of 1705, by sharangad
RaVeN-05 wrote on 2024-04-02, 12:13:
I can't. Keyboard interaction hasn't been implemented yet.
What kind of framerates do you get on your V2200/2100?
Reply 883 of 1705, by sharangad
@robertmo, will investigate framerate issues with other games tomorrow.
Reply 884 of 1705, by sharangad
I guess I can borrow the io code from glidos or at least parts of it. .
Reply 886 of 1705, by sharangad
There's some other game, F1 I think, which has a similar issue with some textures.
Reply 887 of 1705, by sharangad
robertmo3 wrote on 2024-04-02, 13:05:
it looks random helmet generator when turning exists also on real hardware 😉
Yes. That had me worried at one point.
Reply 888 of 1705, by sharangad
Frame sync is also a big problem.
Rr. Exe, the rendition ready app terminates before everything renders. Bits of it render (first 1/3) with sync disabled. If not just a white screen., early frames. I think by studying this app I can get synchronisation working.
Reply 889 of 1705, by RaVeN-05
Video is slower (unsynced)
In alt+x a performance test mode I get 40 as minimum and 80 as maximum fps in intro.
55 I would like to say is average.
Game is limited to 30 fps in normal mode
Reply 890 of 1705, by sharangad
Thanks @Raven-05.
Tomorrow the frame sync., but first the tranya.
Reply 891 of 1705, by robertmo3
other "preserved" game features are:
- pulsating to square cars wheels in the distance,
- 2d textures "fireworks" (visible on a video of original hardware as dirty yellow horizontal lines)
thing i didn't noticed on video of original hardware is:
- gray road bank sometimes blinks
Reply 892 of 1705, by sharangad
Oh is the icr2 exe also called cart. Exe? It might be relevant if I need to feature mask rready special case handlers. I'm hoping it won't come to that.
Rendition. Cfg settings on a per app level will be migrating to the dosbox Cfg file, so I'll probably need to know all the exe names.
Reply 893 of 1705, by sharangad
robertmo3 wrote on 2024-04-02, 13:52:
SODA Offroad has similar issues. Might be a bug with rready.
Reply 894 of 1705, by sharangad
Are there any v1000 videos of ICR2? I'm relying on @raven-05vs videos. He has a V1000.
Reply 897 of 1705, by 88mphTim
sharangad wrote on 2024-04-02, 13:57:
They re-released IndyCar Racing II as CART Racing. They don't seem very different and you can turn one game into the other by moving over the menu and cars.
In your video this morning the sound is playing normal speed. Video was definitely slower than it should be.
Reply 899 of 1705, by sharangad
Thanks. Will need to test IndyCar. Exe as well, just to be sure everything works.
