Reply 980 of 1558, by sharangad
The console doesn't appear to render in vquake 2 with v1k_nopageflip. Aargh! will have to fix this.
r_nopageflip isn't recognised by vhexen 2.
https://www.youtube.com/@sharangadayananda
Reply 981 of 1558, by RaVeN-05
sharangad wrote on 2024-04-08, 08:19:
i am wrong, vid_nopageflip for hexen
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 982 of 1558, by sharangad
BEEN_Nath_58 wrote on 2024-04-08, 08:16:
Well the game runs a little slow than what I would expect, the video has microstutters too. There are graphical glitches with the mouse too, from the start of RReady development
I didn't realise the game was slow. The corrupting menus were already there.
Reply 983 of 1558, by BEEN_Nath_58
sharangad wrote on 2024-04-08, 08:28:
The game runs a little faster in the menu atleast in D3D modes.
Reply 984 of 1558, by sharangad
BEEN_Nath_58 wrote on 2024-04-08, 09:56:
Ok the menus. I have a lot of issues with the menus in team apache.
Reply 985 of 1558, by sharangad
RaVeN-05 wrote on 2024-04-08, 08:20:
Yup that's broken. I've currrently got a build of RReady that can render gameplay in vquake2 and vhexen 2, but not the console and sometimes not the menu. And underwater effects, including the water surface is gone while underwater.
Reply 986 of 1558, by sharangad
In Team apache there's a ridiculous amount of rendering to the front buffer without buffer swaps (i.e. physical frame rate of 0).
Reply 987 of 1558, by sharangad
This should fix all vHexen 2/vQuake 2 vsync issues and hopefully not break anything else. This will not be going on to the store anytime soon. I need to get back to ICR2 and Speedy3D ASAP.
https://1drv.ms/u/s!As-dKk-N73dSmGnDZnwV7I6AnRpO?e=JZXH0a
MD5: 25f5a6143a5cff1a9f23caa9ba081a15
vHexen II works perfectly with vid_nopageflip 1
vQuake2 does not:
Water surfaces do not appear with v1k_nopageflip enabled. This occurs only in vQuake 2 and only with ref_v1k beta 3 or earlier. A patched ref_v1k is required to use native fullscreen (with config.cfg set vid_fullscreen="1" and forced fullscreen in Rendition.cfg disabled). It will not work with an unpatched version of ref_v1k.
From here: http://www.quake2.com/glquake2/verite.html
v1k_nopageflip (default: 0) (0/1)
If set to 1, the verite will use copy double buffering rather than page flipping to update the display. This command offers a performance win, but it also makes water disappear in v1k beta 3 or lower. Other than that, this command should be set to 1 in most cases.
I don't know what version RReady comes with. It's the patched version @Raven-05 supplied. @Raven-05 could you check if quake 2 renders water surfaces with the RReady supplied ref_v1k and v1k_nopageflip=1 on an actual Verité board.
The last know release of ref_v1k maybe able to render water surfaces but I don't know how to get hold of beta 5 or 4.
Reply 988 of 1558, by robertmo3
apple shop has just allowed emulators.
that means not only apple phones and tablets but also apple pcs.
android allows emulators too.
dosbox-staging in its latest release added voodoo and mt-32 support.
mt-32 roms have to be provided independently 😉
Reply 989 of 1558, by RaVeN-05
OK, when power get back. We have for 5 hours per day it, at night.
I am used and patched beta5
Reply 990 of 1558, by RaVeN-05
Maybe blitter V_VBitBlt only used in windowed mode? And while fulscreen patched it's uses swap buffers?
Did hexen also behaves that weird fulscreen or windowed?
BTW still no power (
Just guessing....
Reply 991 of 1558, by BEEN_Nath_58
RaVeN-05 wrote on 2024-04-08, 16:35:
Well what's up with only 5 hours?
Reply 992 of 1558, by RaVeN-05
Tested, beta5 can render correctly with 4 total possible combinations of vid_fullscreen & v1k_nopageflip on real hardware
Reply 993 of 1558, by sharangad
Does it work with RReady? (beta 5)
Reply 994 of 1558, by sharangad
robertmo3 wrote on 2024-04-08, 16:18:
apple shop has just allowed emulators. that means not only apple phones and tablets but also apple pcs. android allows emulator […]
But they have a ton of restrictions.
Reply 995 of 1558, by RaVeN-05
sharangad wrote on 2024-04-09, 01:41:
yes everything works. only whole tint screen is blinking often, while underwater or when picking up items, with nopageflip, probably original hardware slower and it not blinks
Reply 997 of 1558, by sharangad
RaVeN-05 wrote on 2024-04-09, 01:50:
The original hardware has a physical 8 bit palette overlaid on top of 16 bit colour mode. Rready has an emulated fake palette which is probably why it's blinking. Will try and fix that.
Reply 998 of 1558, by sharangad
Also do we need the opengl vsync override in the config file?
It might still be useful to disable vsync properly.
Reply 999 of 1558, by sharangad
RReady will need a special Miro. V1K V1000 bios to run Speedy3D apps.
