Reply 300 of 315, by RaVeN-05
Seems all ok, there is fog, and water splashes behind cars, grass or sand sticks to tires. IDK if there should be rain drops, i didn't saw it , never get noticed in any other versions. Not played so much this game.
https://fex.net/s/asdom2d
EDIT: by having splashes there is very noticeable ho verite uses ordered pixel diffusion. Nice example!
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 303 of 315, by sharangad
Can I ask for change my mind about the video or do you want first dibs on it?
I don't know if you're going to publish it on yt.
https://www.youtube.com/@sharangadayananda
Reply 304 of 315, by RaVeN-05
Formula 1 on RReady superior than on actual rendition hardware.
Yes you can do whatever you want to this video.
Or request another
Reply 310 of 315, by sharangad
This should work on V1000 boards as well without the F1 drivers.
https://1drv.ms/u/s!As-dKk-N73dSmE8_XmHL55en8nRA?e=GUQwwB
MD5: c98f4e55a5bc34c7292ee17f0c00fc39
Reply 311 of 315, by sharangad
@AgentoftheBSOD reports in the RReady thread that F1 runs with the game supplied redline and verite dlls in game folder with v10003d.Uc in the system folder.
"display.drv, v10003d.uc, verite.vxd" in the system folder.
No need for the F1 wrapper at all, on the Canopus Total 3D at least. May work on others.
Reply 312 of 315, by chuky
Good to see you were able to make it work. Thanks for mentioning me. I just tried it a bit with the V2100, it all seems to be fine. I could change resolution from the menu. The default 640*480 seems too much but 512 is fine. I tried the patch that adds joystick support too. It worked although I didn't try with a joystick.
Reply 313 of 315, by sharangad
The testing got worse. One of them was so heavily logged and single stepped it took @Raven05 6 hours to run it.
That was just to get to the crash.
Reply 314 of 315, by robertmo3
chuky wrote on 2024-03-17, 03:31:
don't know if you tried the wrapper or the original F1 drivers or both,
but i guess you can try original F1 drivers files as well:
Re: RReady (Rendition Verite wrapper) Test Build (Alpha 1)
with your v2100 (in case you only tried the wrapper)
Reply 315 of 315, by sharangad
robertmo3 wrote on 2024-03-17, 05:08:
don't know if you tried the wrapper or the original F1 drivers or both, but i guess you can try original F1 drivers files as wel […]
This doesn't work with the V2000.
