First post, by Sphere478
Let’s see those mobiles fly!
The rules as per usual,
Tillamooks only, the software to use is 3dm2000 on default settings. Everything else goes!
file.php?id=133109&mode=view
Sphere's PCB projects.
Reply 1 of 18, by BitWrangler
It's a ..... 'Mook Match! Shades of ROTT deathmatch mode 🤣
Reply 2 of 18, by Horun
Sold my MMX 266 long ago, wish I hadn't... but that was a different time 😀
Reply 4 of 18, by Sphere478
Necrodude wrote on 2023-10-18, 10:06:
Im in! Just need to onstall a OS first on my tillamook system!
95 rtm!
Horun, there is one on ebay. Sl2z4
Reply 5 of 18, by Horun
Sphere478 wrote on 2023-10-19, 01:55:
95 rtm!
Hmm ...my 503+ (rev 1.2A) will do 2.0 v iirc (it is a 1.9v cpu) so it may work ok on it....what do you think ? what board would you recommend ?
Reply 6 of 18, by Sphere478
Sounds worth a try. With mods it seems to be able to work on most boards that I have tried as long as you hit 1.9-2.1v
They specced the I/O at 2.5v IIRC but it doesn’t seem to mind 3.3v I/O
Reply 7 of 18, by gerwin
I am not much of an overclocker, and AFAIK Tillamook is clock-for-clock the same as a normal MMX, but anyways. Want to do something with it.
CPU: SL2Z4 rated 266 MHz https://www.cpu-world.com/sspec/SL/SL2Z4.html
CPU Wire mods: L2 cache enable, VCC2DET grounded
Motherboard: Chaintech CT-5RSA0, ALi Aladdin V Chipset. As mentioned here: Smallest Socket 7 Motherboard
Graphics: NVIDIA Quadro4 100 NVS PCI, 64MB DDR, Passive, Stock clocks. https://www.techpowerup.com/gpu-specs/quadro4 … 0-nvs-pci.c1461
Memory: 1 stick of 128MB SDRAM. Did not tune the settings.
Storage: 8GB SD Card on IDE adapter.
OS: Windows 98-SE with DirectX 7.0, NVidia tweaked omega drivers v1.4403. I think it matches the normal v44.03. Only the 98-SE default chipset drivers.
200 MHz, at 100 MHz FSB, 1,9 Volt -> 1286 3DMarks2000
300 MHz, at 100 MHz FSB, 2,0 Volt -> 1564 3DMarks2000
350 MHz setting did not post at 1,9 Volt, and I did not attempt any other Voltage. For 300 MHz I had to raise to 2,0 Volt to complete the benchmark.
    80.04 KiB
    3DMark2000_200MHz
    80.4 KiB
    3DMark2000_300MHz
Reply 8 of 18, by BitWrangler
Woohoo, reigning champion! That Quadro NVS might be a toughie to beat, even with a better CPU clock. If nobody was gonna do a serious run I was gonna run my thinkpad tonight with software rendering for all of the 200 points I could have claimed made me the guy to beat 🤣
Reply 9 of 18, by Sphere478
gerwin wrote on 2023-10-19, 20:13:
I am not much of an overclocker, and AFAIK Tillamook is clock-for-clock the same as a normal MMX, but anyways. Want to do someth […]
350 mhz unstable is unusual.
Was this 3.5x x 100?
Reply 10 of 18, by gerwin
BitWrangler wrote on 2023-10-19, 22:02:
The next best thing I have are AGP versions of the Gf2 TI / Gf4 Ti4200 / Gf 6200 / Radeon HD3450. But normally the only AGP card I ever dare to use with such ALi Super-Socket 7 boards is the Voodoo 3.
Sphere478 wrote on 2023-10-20, 00:06:
Yes 100 MHz FSB. It was not unstable. Just no post, screen did not come up. But I just tried it again and look 😀
350 MHz, at 100 MHz FSB, 2,0 Volt -> 1626 3DMarks2000
    80.45 KiB
    3DMark2000_350MHz
Reply 11 of 18, by Sphere478
gerwin wrote on 2023-10-20, 00:35:
The next best thing I have are AGP versions of the Gf2 TI / Gf4 Ti4200 / Gf 6200 / Radeon HD3450. But normally the only AGP car […]
It should do 4x 100mhz pretty effortlessly
Do the 4x mod
Reply 12 of 18, by gerwin
Sphere478 wrote on 2023-10-20, 01:56:
Do the 4x mod
Good to hear it can do that. Maybe I will do the mod, but:
The CPU scaling seems to diminish in 3DMark2000.
200 -> 300 MHz good jump.
300 -> 350 MHz underwhelming.
Anyone with a faster graphics card working on Super Socket 7 will surely beat the score.
Then, when I solder the 4.0x multiplier mod will I loose some of the the lower multiplier settings? Currently the Tillamook has a nice set of multiplier options: 2.0x / 2.5x / 3.0x / 3.5x.
Reply 13 of 18, by Sphere478
All supported multipliers should work but some boards may need mods to work properly.
file.php?id=133154&mode=view
The 4x mod will act as a bf2 pulled up on boards that don’t support bf2 pull down. In that case you could add the jumper for bf2 on the board or use a tweaker instead of the surface mods
file.php?id=139915&mode=view
Reply 14 of 18, by shevalier
I don’t mean anything like that, but these are good results for the P1 MMX 233.
For 100*3 you will have to increase the voltage to 3~3.3V.
But that's not what's expected of Tillamook.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Diamond monster sound MX300
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value
Reply 15 of 18, by gerwin
Yeah, I admitted I am not much of an overclocker, and neither is this Tillamook specimen that I have here.
So I understand the mechanism of the BF2 mod now (243571-002.pdf page 18), and instead I made a quick wire mod without any soldering to force the 4x Multiplier.
But the highest speed I could get the system to boot with is 380MHz. That is with 2,2 Volt VCC, and I measure 3,5 Volt I/O VCC3. At 2,1 Volt it could not finish 3DMark. Not going to try 2,3 or 2,4 Volt.
380 MHz, at _95 MHz FSB, 2,2 Volt -> 1657 3DMarks2000
    80.4 KiB
    3DMark2000_380MHz
Reply 16 of 18, by Sphere478
Nice :p
Strange that 400 was a problem. Maybe try a board recap?
Reply 17 of 18, by Sphere478
So you are using a wuadro nvs 280? Which is a 5500?
Try a quadro 2 with 7.76 drivers or a radeon 9800 pro with oldest drivers that work or geforce 3 ti 500 with 7.76 drivers or a radeon 7500 with oldest drivers
5500 is nice but not record breaker usually
Reply 18 of 18, by gerwin
Sphere478 wrote on 2023-10-21, 15:26:
I also suspected the board at first. The board was like 50% recapped already. It had bad caps of a certain type. But the other 50% are still the original ones.
Other evidence suggests it is actually the CPU itself:
- I can run a K6-2+ 500MHz on it.. Just installed it, and it boots up at first try. (3DMark2000: 2382 @400MHz / 2627 @500MHz / 600MHz unstable at 2,1V)
- As noted: Raised VCC voltage made the higher CPU speeds work for the Tillamook. 2x100 Always works fine, even at 1,9 Volt.
Sphere478 wrote on 2023-10-21, 15:30:
So you are using a Quadro nvs 280? Which is a 5500?
No it is another Quadro. NV17 based like GeForce4 MX 440.
