Netburst: Aiming for the Stars
Reply 60 of 460, by paradigital
I’ll definitely give the cap replacement a go, I’m just concerned that the failure is actually something else causing the caps to pop, rather than the caps popping being the problem.
Reply 61 of 460, by supercordo
paradigital wrote on 2023-11-10, 19:01:
Its hard to say if they are old caps.
Reply 64 of 460, by supercordo
Here is my current 3Dmark2000 score. Everything is at stock settings. No overclocking or tweaking settings yet. Disappointed I cant use a regular Asus P4T bios on this board, but that's life.
Reply 65 of 460, by VivienM
supercordo wrote on 2023-11-11, 01:53:
Wow... other than the OS and the socket type (mine was 478), you've basically reconstructed my exact build from late-2001. 1 gig of RDRAM, 1.9GHz Willamette, GF3 Ti500. Impressed that your GF3 Ti500 lived 20+ years, too; mine went bad after less than two years of use...
Reply 66 of 460, by Horun
Nice ! Will be interesting when I can get mine built, 1.8Ghz with a Gainward GF 3 TI 200/450, will be running on i865 board with DDR (if the manual is correct and is supported) so be interesting to compare....
Reply 67 of 460, by supercordo
VivienM wrote on 2023-11-11, 01:57:
Its a Canopus Spectra X21! They made quality stuff.
Reply 68 of 460, by BitWrangler
That does look nice, my MSI and I think the other is Gainward, look like they got reference PCBs done at a cheap board house, then sent them off to Loh Fii Bait, Tackle, Dry Clean and wave soldering Co.
Reply 69 of 460, by Standard Def Steve
The 1.3GHz P4 in my conservatively clocked (1292 MHz) Dimension 8100 obviously wouldn't bring me anywhere near the stars. Fortunately, I found a couple of 478 Willamettes in my drawer of CPUs.
My entry:
P4 1.6GHz @ 2143 MHz on MSI 845PE Max2 motherboard, 512MB single-channel DDR333 @ 2-2-2-6, eVGA 7800GS AGP w/ FW 93.71, XP Pro SP3
Reply 70 of 460, by supercordo
Standard Def Steve wrote on 2023-11-11, 04:47:
My entry:
Nice!!! Its on the board. For fun I just throw my 2.0 wetty in my old Shuttle SS51G.
Reply 71 of 460, by Horun
Great ! Nice seeing a DDR based addition.
Reply 72 of 460, by supercordo
Horun wrote on 2023-11-11, 05:09:
I added the ram type to the score board. Will give us a better idea of what type is really faster.
Reply 73 of 460, by supercordo
The little Shuttle SS51G surprised me. Was able to overclock the FSB to 110x20!!
    203.46 KiB
Reply 74 of 460, by paradigital
Shuttle ss51g was my backup plan if this Asrock board was dead.
However we have success. A recap has brought it to life, fortunately I had some good Panasonic 1500uF 16v caps in my parts box.
1.66 MiB
1.67 MiB
Reply 75 of 460, by paradigital
Well so far just in testing which GPUs will and won't even POST.
Will POST:
Geforce GTX 480
Radeon HD 5970
Won't POST:
Geforce 970
Can't remember if I've got a 780 lying around, certainly don't have anything between GTX480 and 780 from nVidia. Have to go hunt around for my other AMD GPUs, pretty sure they are in the garage attic.
Reply 76 of 460, by DrSwizz
Here are my best results so far.
3Dmark 2000: 8183
3DMark 2001: 13362
    332.89 KiB
    313.37 KiB
Reply 77 of 460, by VivienM
supercordo wrote on 2023-11-11, 03:50:
Mine was VisionTek. They... didn't... make quality stuff, and I think they had a fairly generous warranty. And very aggressive marketing and a resulting big marketshare. All of which is a recipe for hitting financial trouble and going bust.
But by the time my GF3 Ti500 went bad, they had switched from team green to team red, so they sent me a Radeon 9100 as a replacement. Never ended up using it in my Willamette system; I always presumed (though perhaps you guys will tell me otherwise) that the 9100 was a major downgrade from the Ti500?
Reply 79 of 460, by Standard Def Steve
DrSwizz wrote on 2023-11-11, 12:43:
3Dmark 2000: 8183
3DMark 2001: 13362
Dude. You sunk my battleship.
