DOSBox Icon
Reply 240 of 333, by MegaBlast
red_avatar wrote:
Here's my latest DOSBOX icon I made - I went for style above trying to bring "box" into it. I used the DOS font and blue/white t […]
Here's my latest DOSBOX icon I made - I went for style above trying to bring "box" into it. I used the DOS font and blue/white to refer to the theme.
Back on topic, huh?
I really like this DOSBOX writing, it's soo oldskull. 😀
Reply 241 of 333, by ChaosFish
red_avatar: Could you provide the original files for this icon (if you don't mind)? It'd be interesting trying to study it a bit, maybe it could teach me some vector art 😉
I think it's very good, but maybe it can be better by removing the black shadow from the bottom right corner, that is for it to appear better in small sizes.
Reply 242 of 333, by MegaBlast
For me it looks fine. I think only that C: would be better. Anyway for Windows I would build something (ie .ico file) like this:
    29.45 KiB
Reply 245 of 333, by ChaosFish
A different icon can be made just for launching specific applications with DOSBox, just like most software have (e.g. the white page with Word icon inside is for Word documents).
For DOSBox it can be something like this: dosboxmamespaceinvaders-2-32.png (based on kekko's idea, see this)
Reply 246 of 333, by collector
Actually, if I have a shortcut, then it is a shortcut to launch a game, so it will say name of the game.
I usually have 2-3 shortcuts to different versions of DOSBox for testing purposes, so I can just drop a folder or executable on the shortcut of the version of DOSBox that I want to use. For Shortcuts to specific games, I change the icon to one for the game.
Reply 247 of 333, by MegaBlast
I don't have icons for old games (old games didn't have icons!), so I leave dosbox icon then. It's alright, you'll know game is run trough dosbox and the shortcut name says the name of the game. 😀
Reply 248 of 333, by collector
Often, older games were re-released in collections that came with new icons. Almost all of the Sierra collections did.
Reply 249 of 333, by MegaBlast
I've implemented some more interpolation algorithms for one of my program, and while testing I made some dosbox icons using pictures from this thread, that I liked most. Maybe you'll like these icons too.
If I decide which I like most then maybe I'll make a custom DOSBox build with my favorite icon. 🤣
    56.82 KiB
    DOSBox icons.zip
    47.42 KiB
    1408 downloads
    icons
Reply 250 of 333, by ChaosFish
I was thinking of making the DOSBox icon's letters in Inkscape, but found out my vector skills aren't good enough... If anyone is interested to give it a go it would be cool.
I now have Windows Vista (a pre-release version), so I fixed the colors to be be more like the other Vista icons. 16x16 stayed the same.
Better or worse?
Usual ZIP file here:
edit: also changed the windows ICO not to include 128x128 and 96x96 - Vista doesn't recognize those sizes anyway.
    DOSBoxIcon-v6.1.2.zip
    1.03 MiB
    1266 downloads
    474.73 KiB
    On a Windows Vista desktop
Reply 251 of 333, by MiniMax
Rank Moderator
Moderator
6.1.2 looks more vivid than 6.1.1. I like 6.1.2.
_________________
Reply 253 of 333, by ChaosFish
MiniMax - Glad you think so 😀
kekko wrote:
Well, I guess that a 3D dosbox icon with shadows and traslucency would be even more Vista-alike 😀
True, I don't know though, I kind of like it now that it blends in nicely (unlike 6.1.1), yet stands out from the other icons. I think any icon needs it's uniqueness.
Reply 254 of 333, by MegaBlast
Yes 6.12 looks good. Finally you resolved that contrast issue without making colors look ugly.
Now, I have improved my scaling algorithms, here are the icons in 48x48 and 32x32 in following order:
a) original, scaled from256x256 using simple halftoning algorithm, scaled from 256x256 using Polynomial (cubic) algorithm, scaled from 256x256 using Lanczos4 algorithm.
The last (Lanczos) yields the sharpest results from all resizing algorithms.
    13.41 KiB
Reply 255 of 333, by MegaBlast
DosFreak wrote:
Yeah, I noticed that myself. It was even worse before the inclusion of the icon because I would confuse DosBox with the command […]
PS. Oh, one last thing; when I'm alt-tabbing through windows and DOSbox is open, I realise there are 2 separate DOSbox windows;
Yeah, I noticed that myself. It was even worse before the inclusion of the icon because I would confuse DosBox with the command prompt!
Also, If you ALT-TAB then the higher quality icon is being used for the DosBox console while the lower quality icon is being used for the main DosBox program.
I think the console icon should have a black background to reflect the default console (although this will be different for different console programs).
The icon for dosbox window is hardcoded as 32bit 32x32 RGB0 image (no alpha channel!), there is only one resolution. 😒
Furthermore, though icon is in RGB the number of it's colors get's internally reduced to 17!? (Look first image in attachment). I'm not sure why it is like this, most likely for multiplatform portability. It is still possible to make a platform specific build that would have different icons for dosbox window and for console window and both normal ones. It could be even made so that there is different icon showing up in the explorer, in the main window and in the console window. (blue is for console, and red for dosbox window)
    11.04 KiB
    11.44 KiB
    10.49 KiB
Reply 256 of 333, by DosFreak
`Moe` wrote:
Uhm, somehow my mind insists on reading "BOSDOX" from that. Weirdness 😉
This happened to me as well today while reviewing this thread.
BOSDOX! Weird!
(Check out the earlier ChaosFish Icons.....what an evolution!
Make your games work offline
Reply 257 of 333, by MegaBlast
Never happened to me. 😀
I like ChaosFish's icon, I use it as icon for shortcuts to games run trough DosBox. For Dosbox.exe I prefer red D: icon and for DosBox's windows: red D: for main window and blue D: for console. 😉
Evolution indeed, one could make image with all the icons starting from beginning till now, to visualize it. 😀
PS. I'm not sure if I mentioned this before, if you click on close button in console window the DOSBOX crashes! 😵
My signature. 😀 I'll have to put something in here later.
Reply 259 of 333, by cdoublejj
I made this some time a go it needs perfecting this i what i got when i took the name Dos-Box literally. 😊
    DosBox.zip
    1.96 KiB
    1127 downloads
