DOSBox Icon
Reply 60 of 333, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
he he, the floppys look funny, too. I have to try how it'll look in smaller sizes.
Chaosfish: I like the futura font, only now that I look at it again, the other icons are more "dos-like" 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 62 of 333, by DosFreak
Problem there is that Windows command prompt is a "C:\" so:
1. Using "C:\" as an icon would promote more confusion from users thinking that DosBox is the "Command Prompt" dosbox.
2. "C:\" is used by MS alot as noted above and DosBox shouldn't be associated with anything MS. (Even tho it does run DOS games....)
Make your games work offline
Reply 63 of 333, by Kippesoep
Perhaps "A>" should be used instead. The default DOS prompt doesn't include the path anyway. It may have been used by MS, but the "A>" prompt originates in CP/M.
My site: Ramblings on mostly tech stuff.
Reply 65 of 333, by Guest
DosFreak wrote:
Problem there is that Windows command prompt is a "C:" so:
1. Using "C:" as an icon would promote more confusion from users thinking that DosBox is the "Command Prompt" dosbox.
2. "C:" is used by MS alot as noted above and DosBox shouldn't be associated with anything MS. (Even tho it does run DOS games....)
Well then, how about a 3d box with a black window with "DOSBOX" written on it with a arrow pointing to a picture of a computer for the Setup icon, if there is a setup.exe associated with DOSbox, and just a box with the black window labeled DOSBOX for dosbox.exe
Reply 67 of 333, by avatar_58
Why not? MS isn't the devil so its not going to hurt anyone. After all most people did use "ms"-dos for their old games so "C:" has become the flag for it. Just look at the abandonware site "C:DOS" 😉
I'm just saying that we don't have to take desperate measures to avoid MS related icons.
Reply 68 of 333, by ChaosFish
Hi again,
I don't want to seem rude or nagging, but to Qbix:
I would really love it if you say your opinion about the icon. I will do whatever I can to change it so you'll find it good enough to use. Heck, I'll even make a complete different one, just tell me how you want it to be like 😀
I'm only saying that because you said back then that DOSBox doesn't have an icon only because you still haven't seen a good one yet. And it'd be a honour giving my contribution to DOSBox.
Reply 69 of 333, by Qbix
Rank DOSBox Author
DOSBox Author
Sorry ChaosFish
I simply forgot about the matter.
My mind is occupied with lots of small things.
I will pin this thread so it will not be forgotten.
I agree that an icon is nice to have and you seem to have the necissairy skills in order to create one to my liking. I will get back to this thread.
Water flows down the stream
Reply 70 of 333, by ChaosFish
New version!
The colors of the box are better now, it doesn't look faint anymore.
Obviously the letters are different now.
I only made the 32x32 icon so far, so after I'll get feedback from Qbix and if he will like this I will work on other sizes. The problem with the other sizes is that I didn't find a suitable font yet, but it's workable.
To really get an idea of how the icons feel like and see which color you like the best, extract the attached zip file to desktop and see for yourself (try with different wallpapers to get a better idea).
    2.32 KiB
    2.31 KiB
    2.31 KiB
    2.31 KiB
    dosboxicon4-ico.zip
    10.07 KiB
    324 downloads
Reply 71 of 333, by ChaosFish
Slight improvement:
The icon now has a (slight) black border, so it looks better on all backgrounds (especially blue ones). You may ignore the attachments in previous post 😉
Reply 73 of 333, by Qbix
Rank DOSBox Author
DOSBox Author
the tiny black border is fine. However I would appricate it if the text looked more blended to the background.
Reply 74 of 333, by Drek
This is funny. One of the first things I did after I installed DOSBox was look for a good icon - I didn't find one...
@ ChaosFish - I know how much work goes into even making small things like icons. I appreciate the efforts. Personally I like 4.1.
ASRock 970 Extreme3 mainboard
AMD Phenom II X4 955BE
8 GB DDR3
Sapphire Radeon HD 6770 1GB
Windows 7 64 Pro
Reply 75 of 333, by ChaosFish
Thanks Drek, I like 4.1 too 😀
Qbix, I'm not sure what you meant by more blending. Do you want the text to be a part of the box? Like a wooden embossment? I'll try to make something, but it will help if you could be a bit more specific.
Reply 76 of 333, by Drek
Ha, I actually meant 4.1 orange, didn't notice they were all 4.1. 😀
They're all good, but the orange is the one I like best.
8 GB DDR3
Windows 7 64 Pro
Reply 77 of 333, by ChaosFish
Well then, feel free to download the .ICO and use it then 😉
Again, to get a real idea you should download it and view on the Desktop (rather than on VOGONS).
Reply 78 of 333, by Drek
Have done so, somehow missed the icons at the bottom - thought they were all pngs.
Nice looking icon, much nicer than the old boring MS default. 😀
8 GB DDR3
Windows 7 64 Pro
Reply 79 of 333, by ChaosFish
Ok Qbix!!
I think it looks much better now!
So, changes:
* As Qbix wisely suggested, the text look more "blended" (a little wood texture I made).
* Cound't find suitable fonts for other sizes, so I just made the other sizes' fonts myself 😀
* A neat 16x16 icon
* Also everything else improved a little bit
So, what do you think Qbix? 😀
P.S. btw, I let go of the 128x128 icon. I don't think it's actually needed.
    7.25 KiB
    4.35 KiB
    2.13 KiB
    844 Bytes
