DOSBox Icon
Reply 80 of 333, by ChaosFish
emptybox5.zip contains the latest empty box version in PSD (photoshop) format. With layers and all.
dosboxicon5.zip contains each icon in each size, AND, an "all in one" icon which contains all the sizes (this one is ready to be used on the program itself).
    emptybox5.zip
    96.69 KiB
    318 downloads
    dosboxicon5.zip
    32.66 KiB
    430 downloads
Reply 81 of 333, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
th5 64x64 icon looks VERY nice
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 83 of 333, by ChaosFish
And here's an alternative All In One icon to use.
This one only uses 256 colors, so it's:
1. more compatible with all machines (also looks better on older machines)
2. takes up less space (now it's only 12.7 kb)
So, you should ignore the previous "AllInOne.ico" and use this one, because the change is 100% unnoticeable to the naked eye.
Reply 84 of 333, by ChaosFish
Hmm sorry to double post but,
I noticed Mac uses 128x128 icons as thumbnails. And maybe Vista too.
Do you think there should be a 128x128 icon anyway?
Reply 85 of 333, by ChaosFish
Okey. Last update for now:
* Added 128x128 icon
* All icons look even better
    7.23 KiB
    4.38 KiB
    2.15 KiB
    854 Bytes
    26.49 KiB
Reply 86 of 333, by ChaosFish
And here are the icons in ICO (windows) and ICNS (mac) formats.
I suppose there isn't a special icon format for Linux? (please correct me if I'm wrong)
I'm done for now. Qbix, I'll be waiting for your comments to make any further improvement. And please let me know your thoughts anyway 😀
    DOSBoxIcon-v5.1.1.zip
    66.52 KiB
    324 downloads
Reply 88 of 333, by Qbix
Rank DOSBox Author
DOSBox Author
The font is a great improvement.
I was wondering if if you could made the brown border a bit smaller so that the X and B don't thouch the grey X
Linux at my place uses png at least for some icons
Water flows down the stream
Reply 89 of 333, by ChaosFish
Okay, improvements:
* The big X is thinner. I couldn't make the border thiner without significantly degrading the quality, so this was the only way to make the X and the B a little farer from the big X. You can notice in the 128x128 image that the X still touches the big X a little, but that's unpreventable (talking after trying all possibilities without editing the actual font of the text).
* The shadow of the letters goes the other way.
    26.31 KiB
    7.29 KiB
    4.39 KiB
    2.16 KiB
    782 Bytes
Reply 90 of 333, by ChaosFish
Inside this ZIP is the icon in these formats:
* PNG (24 bit)
* PNG (256 colors)
* ICO (256 colors)
* ICNS (32 bit)
* XPM (256 colors)
All PNG files are optimized to minimal bytes count.
Please let me know what are you thuoghts.
    DOSBoxIcon-v5.2.zip
    159.95 KiB
    292 downloads
Reply 91 of 333, by ChaosFish
New version, improvements:
* Better shading
* The "S" in 48x48 fixed
* Better 16x16 icon
    27.04 KiB
    7.39 KiB
    4.49 KiB
    2.22 KiB
    800 Bytes
Reply 92 of 333, by ChaosFish
ZIP file contains:
* PNG (24 bit)
* PNG (256 colors)
* ICO (24 bit)
* ICO (256 colors)
* ICNS (32 bit)
* XPM (256 colors)
    DOSBoxIcon-v5.3.zip
    212.79 KiB
    356 downloads
Reply 93 of 333, by ChaosFish
Eep! Quick update!
All boxes less than 128x128 are sharper.
    27.04 KiB
    7.68 KiB
    4.62 KiB
    2.26 KiB
    811 Bytes
Reply 94 of 333, by ChaosFish
Usual ZIP file.
Last update for today, I promise!!
    DOSBoxIcon-v5.3.1.zip
    215.38 KiB
    292 downloads
Reply 95 of 333, by ChaosFish
Just to give you a feeling... 😉
    92.33 KiB
    On the desktop...
Reply 96 of 333, by ChaosFish
New version, 1 little change:
* Letters are a bit more yellow
    26.98 KiB
    7.67 KiB
    4.61 KiB
    2.25 KiB
    806 Bytes
Reply 97 of 333, by ChaosFish
Usual ZIP file, contains icon in all useable formats.
    DOSBoxIcon-v5.4.zip
    212.21 KiB
    296 downloads
Reply 98 of 333, by ChaosFish
This might very well be the last and final update! (up to Qbix)
* A little "outer glow" aroung the big X, making the icon more vivid
* Box in all sizes less than 128x128 look even better (16x16 one left unchanged tho)
    27.44 KiB
    7.72 KiB
    4.64 KiB
    2.27 KiB
    806 Bytes
Reply 99 of 333, by ChaosFish
As usual, ZIP contains all useable icon formats.
    DOSBoxIcon-v5.5.zip
    215.2 KiB
    334 downloads
