Reply 20 of 20, by Shponglefan
chinny22 wrote on 2024-01-15, 04:41:
Man that mixer is almost as big as the PC! but it's just lying around then makes perfect sense.
It's from an older studio setup I had. I was thinking of selling it but hadn't gotten around to it yet. Turns out it came in handy of this project.
I think in the long run if I decide to make this a permanent setup, I'll probably go with something more compact like this ART 8-stereo channel mixer. Doesn't have any EQ options or fancy routing, but is much more compact.
150.05 KiB
I run audio extension cables from the back of each PC and manually plug the speakers into which ever PC I'm using at the time, takes a lot less space but naturally no ability to mix different sources
That can work as long as there is no need to mix multiple sound cards for things like digital audio and music.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
