Reply 20 of 25, by badmojo
Errius wrote on 2024-01-24, 17:41:
Are passive mixers safe? I was always told you shouldn't directly connect the outputs of two different audio devices.
I've been using this little passive Rolls for years without issue: https://rolls.com/product/MX41b
You lose some gain of course, but not enough to be a problem.
Reply 21 of 25, by digistorm
Those passive mixers will probably be safe because they don’t just connect the outputs together. There is enough resistance between the input and the point where they are all joined that they are not able to short each other out. That’s why the output signal is lower and needs more amplification.
Reply 22 of 25, by Sphere478
Yes there are two resistors on each port one for right and one for left. Then the trim pot for varying the volume of the signal. (Probably on the common)
Sphere's PCB projects.
Reply 23 of 25, by orcish75
Sphere478 wrote on 2024-01-21, 15:16:
Nice! :p
I wonder if there is a version with more ports🤔
Lots of options on Aliexpress, active and passive.
https://www.aliexpress.com/item/1005006374031 … 7Cquery_from%3A
Reply 24 of 25, by orcish75
Tempus wrote on 2024-01-12, 09:25:
I use this 1988 mixer with a 486 and a Pentium 3.
Are the inputs stereo? Most pro mixers I've come across have maybe 2 stereo inputs, the rest are all mono. Most DJ mixers seem to be stereo, but only 2-4 channels, so not much good for multiple soundcard/rompler setups.
Reply 25 of 25, by Tempus
orcish75 wrote on 2024-01-26, 07:35:
They are mono inputs, with panning set to left and right, so 16 channels becomes 8 stereo channels. The ouputs are stereo. One set of balanced (XRL) and one set of line ouputs (6.2mm jacks). I have to use an attenuator for channel 1 and 2 since they are microphone level. (Seen on top of the mixer).
    1.6 MiB
    1.24 MiB
    1.85 MiB
Akumajō Dracula: Belmont's Theme Roland MT-32 | Yamaha YM2151
