Reply 20 of 40, by Scythifuge
kolderman wrote on 2024-02-07, 10:29:
One reason i dual boot win7 with xp. I can potentially install under win7, do a reg diff, then play under winxp. The game partition is mounted as D on both.
I am LOVING using Windows XP again (and I keep looking for ways to do things I do on my main PC on my XP pc, such as using an XP Pen drawing display - going to try that next,) but I also miss Windows 7. If I could, I would have only MS-DOS/WfW 3.11, 95, 98SE, XP, and 7 on my PCs. I am so thoroughly disgusted with Microsoft and Windows 10 that I am switching to Linux for future builds. Almost every new game is crap, and new games (and "security" updates) are the only reason to have Windows 10, in my opinion. I didn't downgrade to Windows 10 until 2018, when I built my first Ryzen machine and "needed" DirectX 12.
Reply 21 of 40, by chinny22
I don't think windows 10 (or 11) is terrible enough to move to Linux, I'd still call the OS Serviceable rather then enjoyable.
I still don't actually like them and think simplicity of use the GUI has been going backwards, even starting with Win7
but I don't find much about modern computers enjoyable, rather just treat them as a tool to get things done.
for tinkering, gaming, etc I didn't get past XP
Reply 22 of 40, by Scythifuge
chinny22 wrote on 2024-02-08, 04:40:
I don't think windows 10 (or 11) is terrible enough to move to Linux, I'd still call the OS Serviceable rather then enjoyable. I […]
Agreed on most point (I keep feeling compelled to start heavily researching Linux.)
I read a comment on a youtube video about XP which talked about how XP felt welcoming and inviting, but Windows of today is cold and soulless. It is a bloated mess. It is ironic how often I use my Windows 10 PC to play dos games or emulate a plethora of x86 machines via 86box. I wish I had a shell which coverd the Windows 10 crap with a classic looking shell that shows me only what I want and need. I know that there are ways to do something like this alread (and I am considering it - even the progman.exe way to make 10 look like Win 3.x,) but I want to go deeper. I have fond memories of the Windows Trilogy (3.x, 9x, XP,) and consider it a golden era. It is probably why I have been on Vogons a lot more these days, and why I am working on multiple retro projects at once.
Reply 23 of 40, by RandomStranger
Scythifuge wrote on 2024-02-08, 03:26:
I've been daily driving Linux for 4 years and most games work without issues. There are problems with some multiplayer games' anti-cheat systems, but if you play single player, playing modern games is almost as effortless as on Windows with very little performance hit. While playing older games are sometimes easier on Linux than on modern Windows.
It was during Windows 8.x that I started dual booting Linux and however disliked those were, it was 10 that made me transition fully. Windows 10 is absolute garbage and it is definitely terrible enough to move to Linux.
Reply 24 of 40, by dr_st
In the end most people end up being comfortable with whatever they first started using. To some - 9x/XP is the "golden era". Put someone whose first Windows was Windows 10 in front of Windows XP and they will curse at the strange and unintuitive "garbage UI" just the same.
Like - what do you mean - you have to click through multiple submenus with names written in tiny fonts to get to the app you just installed? And why is there no convenient system tray popup to control Wifi, Bluetooth, and Wireless hotspot at the same place? And how do I connect my PC to a wireless display???
Reply 25 of 40, by acl
(Evangelist mode on)
GOG games installs well under Linux.
There is even Lutris, which is a multi store client. A very popular tool for Linux gamers. You can log it into your gog/steam/humblebundle/etc account and have it to install the games. It installs automatically the correct wine/proton/libs version to have the game to run the best. (Based on comunity contributed recipes ).
Example : https://lutris.net/games/star-wars-episode-i-racer/
It's not a shady software from GitHub that will steal your accounts. The packages is available in most Linux distributions official repositories.
https://packages.ubuntu.com/jammy/lutris
Linux gaming has never been so easy (and I'm gaming on Linux for like 18/20years.)
226.56 KiB
Source : https://en.opensuse.org/images/0/05/Lutris_screenshot.jpg
Modern games like Cyberpunk, Hogwarts Legacy, Baldur's gate or Diablo4 runs perfectly. When a game does not, most of the time its because of some DRM or anticheat.
(Evangelist mode off)
Installing the game under Linux then copying into an xp/w9x system should be possible as well.
Reply 26 of 40, by kolderman
Also why I have been, from day 1, downloading and archives the full offline GOG installers for all GOG games earlier than about 2004 (that I am likely to want to play on a retro PC). I am afraid at some point the new installers will screw me over.
Reply 27 of 40, by Scythifuge
Has anyone managed to get GOG's Shadowrun Returns to run on XP? XP and XP-era hardware are supported according to the system requirements (1.4Ghz CPU so I am assuming SSE2 is not needed,) yet when I attempt to run the game on my XP machine, it immediately crashes with a complaint about shadowrun.exe... This is a bummer, since I was hoping to see how such a "late" game would run on XP.
Reply 28 of 40, by Shagittarius
Scythifuge wrote on 2024-02-08, 19:32:
Has anyone managed to get GOG's Shadowrun Returns to run on XP? XP and XP-era hardware are supported according to the system requirements (1.4Ghz CPU so I am assuming SSE@ is not needed,) yet when I attempt to run the game on my XP machine, it immediately crashes with a complaint about shadowrun.exe... This is a bummer, since I was hoping to see how such a "late" game would run on XP.
I have no problem running it on XP SP3:
Xeon 5690
Geforce 780ti
3GB RAM
I'm using the installer version 2.3.0.12, the timestamp on the file says it was created on 9/01/2021. I would download the latest and check but GOG is down right now.
Reply 29 of 40, by Scythifuge
Shagittarius wrote on 2024-02-08, 20:00:
I have no problem running it on XP SP3: […]
Xeon 5690
Geforce 780ti
3GB RAM
Thank you for letting me know. I just checked my archive and I had downloaded it back in 2014. I will download it again when GOG goes back online. So far, most other games work (expect for Revenant - GOG and AvP CLassic - GOG.) I hope I can get it running. I love Shadowrun.
Reply 30 of 40, by DEAT
Scythifuge wrote on 2024-02-08, 22:32:
Revenant should just work in XP - it works fine in Win98, only needing an _INMM injection for playing the OGG files.
Reply 31 of 40, by Horun
nevermind
Reply 32 of 40, by Joseph_Joestar
DEAT wrote on 2024-02-06, 07:07:
Joseph_Joestar wrote on 2024-02-06, 06:50:
Off the top of my head, only the GOG version of Quake 2 was problematic. It would install fine on XP, but the game executable wouldn't run, as it appears to require Windows 7. To be clear, I'm talking about the original Quake 2, not the remaster.
The GOG release works fine on Win98 - see my previous post.
I was talking about WinXP, not Win98. At a guess, WinXP compatibility may depend on when the installer was downloaded. Maybe GOG made some recent updates to Quake 2 which broke it.
For reference, I downloaded the Quake 2 GOG offline installer about six months ago. And while the installer itself does work, the actual game executable crashes with an error when I try to run it under WinXP 32-bit.
Reply 33 of 40, by Scythifuge
DEAT wrote on 2024-02-08, 22:49:
My original install discs work, and I can select enhanced lighting in the options, with the X800 being a decent card for this game. However, there are intermittent pauses. Maybe it needs a patch. It is just weird that the GOG install won't work. I may try dgvoodoo or nglide and see how that goes. I think that the 2nd disc can be copied to a folder and Revenant be set to look in that folder, eliminating the need to have the 2nd disc in the drive (probably with a crack, however.)
Joseph_Joestar wrote on 2024-02-09, 04:22:
This seems to be a problem with quite a few games which otherwise work in XP with the original discs. As I progress with installing and testing each game, I will probably make a list of GOG games which fail to run on XP. Maybe I will make a new thread about it and see if answers can be found. While I have a vast library of original discs and/or can acquire disc images, I like the GOG option for having games just run without needing discs or no-cd cracks (when they actually work.) While I love having working optical drives and use them for many things, one of the goals is to create a library of XP compatible games and DOSBox and being able to click n' play.
Reply 34 of 40, by Scythifuge
Xeon 5690
Geforce 780ti
3GB RAM
I am still getting crashes. I think that despite the listed requirements, I am running something too old. Maybe it needs SSE2 or a better video card. I am running an ATI AIW X800 XT.
Reply 35 of 40, by Shagittarius
Scythifuge wrote on 2024-02-11, 03:55:
Xeon 5690
Geforce 780ti
3GB RAM
Hey I just tested this on my Xeon 3230 machine, its got 2GB ram and a 9800 pro (128MB) on XP. As long as I turn off HD textures the 9800 pro has no problem running it, it even runs well at a 1024X768 res. I think your X800 should be fine, you're saying that it crashes before you even hit the starting menu? I don't have a machine that could test without SSE2 so I can't check that.
What CPU are you using?
Reply 36 of 40, by Scythifuge
Shagittarius wrote on 2024-02-11, 05:34:
Xeon 5690
Geforce 780ti
3GB RAM
An Athlon XP 3200+.
Reply 37 of 40, by Shagittarius
Scythifuge wrote on 2024-02-13, 05:07:
An Athlon XP 3200+.
I do have one of those but its hooked up to a 64MB Voodoo 5 with only 64MB of ram...still I suppose I can see if it launches or not.
EDIT: Yeah it crashes right away with an Athlon XP 2400+. Like I said though it's got a Voodoo 5 in it.
Reply 38 of 40, by Scythifuge
Shagittarius wrote on 2024-02-13, 22:36:
An Athlon XP 3200+.
It could definitely be the Voodoo5 in your case since it isn't a DX 9 card. I found an anecdotal post somewhere where someone claimed it ran on some form of Athlon XP and an X800, I tried their "version" and it still crashes. I tried removing GOG-only files to no avail. I might have to give up on this one. However, that is difficult for me to do since I apparently exceed the minimum system requirements. Are there any SSE2 CPUs running at 1.4Ghz? I'll have to look into that. It could also be some other strange incompatibility such as my drivers, or something else. I know I can play it on my main PC with ease, though this Athlon XP is a Shadowrun/Cyberpunk-genre inspired PC. I am using SHODAN for the My Computer icon, and the cover of the Shadowrun 2e rule book as my desktop wallpaper. This and other things were how I had my XP machines set up, back in the day.
Reply 39 of 40, by Horun
Curious what Shadowrun Returns version is the GOG version, just curious...
