Reply 20 of 26, by shamino
momaka wrote on 2024-03-08, 08:40:
shamino wrote on 2024-03-08, 00:58:
Try swapping to a different molex connector from another harness, unless you know the one you're using is good with other high powered cards.
Honestly, that's another myth that I keep seeing on various gaming forums, at least when it comes to these older GPUs. With new gen stuff pulling 200+ Watts and being a lot more sensitive voltage droop (due to current monitoring on the 12V rail - something that the GF6 series don't have... or even GPU power monitoring for that matter), I can understand.
That said, if the connector is dropping so much voltage because of a bad connection, you would see the connector melt / darken pretty quickly.
All it takes is a bad wire. How much current will cause a problem depends on how bad it is.
Whether you'd see a melting connector also depends where the problem is.
Reply 21 of 26, by Karbist
This topic reminded me that I still have an artifacting Gigabyte 6800GT PCIe stored somewhere, so I dug it up and this is how post screen looked like:
1.43 MiB
So I put the card on the pre-heater, applied hot air and chip was floating right at 190C.
ran furmark for few minutes and card reached 80C (probably need a better paste) and it was stable, no artifact .
201.63 KiB
Reply 22 of 26, by Socket3
Karbist wrote on 2024-03-10, 12:00:
This topic reminded me that I still have an artifacting Gigabyte 6800GT PCIe stored somewhere, so I dug it up and this is how po […]
I'll give it a shot when I get a pre-heater - they're not expensive.
Reply 23 of 26, by momaka
Nice, great to hear you got it revived! 😀
Better paste / thermal compound won't help you lower the temperatures that much though - maybe 4-5C max, which is still too much for these cards, especially one that has failed already.
Again, my recommendation is to keep temperatures below 60C (preferrably in the mid-50's max)... which won't be possible with the stock cooler.
Replacing it with something like the Zalman VF-1000 is a good start... though those were (and still are) rather pricey... not to mention even difficult to find nowadays (unless you look for a broken video card on eBay that has this cooler - some MSI GeForce 8800 GT cards did, among others.) Or taking a cooler off of another card and adapting it for the GF 6800 is another option if you're handy / don't mind DIY. Just needs to be a cooler from a card rated for 120W TDP or more.
Socket3 wrote on 2024-03-10, 13:50:
Pre-heaters are somewhat of a waste of money, IMO. You can easily make one from the components of a heat gun or an old toaster. I was going to go that route, until I found that the kitchen (gas) stove is actually better than any pre-heater I could buy - lots of power (heat) and a lot of room for adjustment, allowing me to do both small and big PCBs. I've also done it on an electric stove, but it can be a bit more tricky depending on what you have. "Modern" IR-based electric stoves with touch-sensitive buttons are a bit of PITA to use. But anything of the older kind with an "exposed" coiled heating element (like one found in the oven) and a proper knob for variable power makes for a pretty good pre-heater.
Just place the PCB on blocks of wood or other object to suspend the PCB a few inches (maybe 3-7 cm) above the stove, and that's it. Need to have a type-k thermocouple meter, though, to monitor PCB temperatures. With that and hot air station, you should be able to do quite a bit.
shamino wrote on 2024-03-09, 01:20:
If it's a bad wire, either the card won't start (detects molex connector is not present or simply drops out due to disconnection of power for GPU V_core) or will drop out intermittently (again, for the same reasons.) Whichever the case, this type of failure is usually very unpredictable in nature... whereas in the case of O/P's card, the failure seems to be much more predicable - crashing only under high GPU/mem. load and after the GPU has ran for a while / reached a certain temperature.
Bad solder joints on the PCB are out of the question too, as this is a multi-layer PCB and the power connector is soldered to multiple layers with vias connecting all of the power traces together.
So that only leaves weak contacts on the connector... which might loose a few 100 mV at most (along through the wires), but hardly more. At 4-5 Amps current draw (about 60W for these 6800 GPUs), any more would start producing a lot of heat around the connector. At 1V drop, that's 4-5W of power. But even if that was the case, 11V on the 12V rail won't crash these 6800 cards - they will happily run down to even 10V. If the connector was dropping 2V, you'd see it.
Reply 24 of 26, by Socket3
momaka wrote on 2024-03-10, 18:39:
Unfortunatly I don't have the spare time or energy to spend on DIYing such a device, I'd rather purchase something dedicated, pre-made, that fits neatly on my desk. A workable pre-heater for video cards is ~100$. I'm sure a good DIY heater can be built, but it's not for me. I'm not talking about proffesional grade hardware, that fit whole mainboards, have 4 temp sensors and seperate heating zones, come with two hot air pump supports and a built in adjustable microscope stand... one of those would be nice to have, but those are well over 500 euro, and not worth the investment for someone like me who ocasinally dables in this kind of work as a hobby.
Reply 25 of 26, by Karbist
This is the preheater I have, Gordak 853: https://www.aliexpress.com/item/1005002785030658.html
3 in 1 version, Gordak 863: https://www.aliexpress.com/item/1005001711285885.html
but if you plan to work on motherboards you need something bigger like T8280.
Reply 26 of 26, by momaka
Socket3 wrote on 2024-03-10, 22:30:
Same.
That's why I suggested (and myself have resorted to) using a kitchen stove top. I rarely do more than 3-5 BGA repairs a year, if even that many anymore. I already had the type-k thermocouple from before, though.
But anyways, I can understand wanting to have a separate tool for the job rather than resorting to quirky methods. Plus, I forgot to mention that if you're married or live with others, using the kitchen stove for this kind of stuff may not always be appreciated by everyone 😁 , even though it's harmless. Now, as for over reflows - those I frown upon too and would not attempt one in my oven, since I use it for making bread (and other stuff) somewhat frequently.
