Another Voodoo 2 SLI bridge
Reply 20 of 30, by Tevian
The next test PCB will be the fan carrier board. I already have two Noctua 40mm to try it out. The LEDs are plenty bright and I think they turned out well. I didn't know how much light would shin thru the PCB but I'm happy with the results!
I'm not sure how many folks use or need a multi-PCI spanning bridge, but I decided to craft a 40mm and 60mm bridge with custom artwork. The 40mm has a knock-out Quake logo but decided to not add LEDs, while the 60mm bridge has a knock-out and LED backlight. Not sure it was totally needed but I trace length matched on the 40mm and 60mm PCB because I had to route around the knock-out causing some traces to have <10mm mismatch.
Once I know the other test PCB works, I'll upload these designs to GitHub for everyone! Thanks for the inspiration for everyone who contributed to the original post by @matze79.
256.87 KiB
270.34 KiB
184.95 KiB
414.13 KiB
Reply 21 of 30, by H3nrik V!
Woa, that's really cool!
Didn't the "need" for a 60 mm version arise from the extra room for fans?
Reply 22 of 30, by Tevian
H3nrik V! wrote on 2024-03-19, 11:30:
No... The 20mm bridge fan carrier board (using 40mm fans) "should" work. I've done a simple test of placing the two fans on top of the Voodoo2s and they really do a good job of pushing air between the cards. The 40mm and 60mm span gives a bit more distance and regular case air flow would probably be enough. Besides, the 20mm version with two fans covers both cards. The larger span puts both card faces out of reach for the two fans and might get pretty ugly with multiple fans trying to cover both. A single larger fan might work, but I don't think I'd like the aesthetic very much. 😋
Reply 23 of 30, by Tevian
Finally got the fan carrier board assembled and preliminary testing. So far, it's looking really good!
411.28 KiB
1.01 MiB
604.47 KiB
I did some super limited testing (I ran out of time but wanted to post the results) with a thermal camera. Running Quake v-sync off for 10 minutes with and without the fan bridge, the main 3DFX processor is cooler by 15°C with bare chips. With attachable heat sinks, I'm sure it would be even better.
200.37 KiB
159.08 KiB
Reply 24 of 30, by H3nrik V!
Holy fudge, that is absolutely awesome!
Reply 26 of 30, by Tevian
Got the latest boards and they're looking pretty nice. The 60mm bridge has 8 neopixels and an ATTINY85 micro to control them. I'm going to assemble one soon to see if it works...
413.94 KiB
404.18 KiB
647.96 KiB
178.25 KiB
267.25 KiB
I don't like the mask relief on the silkscreen parts so I'm going to remove those on another revision.
Reply 28 of 30, by H3nrik V!
Tevian wrote on 2024-04-06, 00:35:
Is the neopixel an ARGB LED?
Reply 29 of 30, by Tevian
H3nrik V! wrote on 2024-04-06, 13:27:
Ah yes, they're addressable! I'm using these, https://www.adafruit.com/product/4691.
I completely suck at coding BTW. This little flame effect was written by chatGPT. It's not what I want, but it works ATM. Dave's Garage YT channel had some great-looking fire effects, but the coding is all for ESP32 and I don't really understand how to port that to a small ATTINY85. Oh well...
675.64 KiB
Here's a short vid demo!
https://www.youtube.com/watch?v=B25BmlSav9U
Reply 30 of 30, by H3nrik V!
Nice looking!
Regarding the ESP32 code, the attiny may be too weak for a code port to make sense
