Reply 20 of 24, by asdf53
bten wrote on 2024-03-14, 18:28:
Thank you for testing for me, I appreciate it.
Gonna return and get an FX card from a known manufacturer.
I also found this:
https://forums.guru3d.com/threads/geforce-2-m … -64mb-400.2964/
I bought Apollo Gf2 Mx 64m and had 1200 on 3dMark2001. Took off heatsink and found Mx200 on chip. ;(
Should be another piece of evidence in case the seller doesn't believe you.
Reply 21 of 24, by bten
asdf53 wrote on 2024-03-14, 20:13:
I also found this: […]
I also found this:
Thank you. Again I appreciate the help.
Learned my lesson buying no-name gpus. Better it happened on a cheap one than if I bought something pricey.
Staying away from this "Apollo" brand 🤣.
Reply 22 of 24, by sydres
As the original poster in the weird geforce2 post, I'd like to know if your card came in this box?
1.47 MiB
Under hwinfo
Core=200mhz
Ram=125mhz
3dmark99-2603
3dmark2000-2122
It might not be fast but seems fairly stable, and image quality is better than the tnt2 m64 I had in the system
Reply 23 of 24, by bten
sydres wrote on 2024-04-06, 17:35:
As the original poster in the weird geforce2 post, I'd like to know if your card came in this box? IMG_20240406_132209564.jpg Un […]
Under hwinfo
Core=200mhz
Ram=125mhz
3dmark99-2603
3dmark2000-2122
Yes, identical box with identically odd peeling adhesive material.
