First post, by Guest
I am hasty on playing with the Regedit.
I downloaded the 2.1.0 from another thread here and installed the application.
I currently have this problem
When i right click on a Bat Com Exe i see no VDMS in my little menu.
(i am also including a file list that is installed see image)
I am under admin (only name up i can log in to)
I did reboot (multiple times)
I am runnin windows XP SP1
I used to run VDMS 2.0.4 and completly uninstalled it. The issue with that is i cannnot get the launch pad to work at all when i try installing it. As i get an error. (ends with 7007e i think.) when i installed the 2.0.4 i got some errors regarding installing it and i found some reg entries that allowed me to use it. but launchpad no go.
Any help on either of this would be greatly appriciated.
(tryin to run Startrek a final unity)
    83.1 KiB
    93 downloads
Reply 3 of 4, by vladr
Something (antivirus, etc.) has very likely been installed on the system and is interfering with regsvr32. For those for whom VDMSound was instaling before but not after: what was installed since it last worked (installation-wise)?
Cheers,
V.
