First post, by Unregistered
in advanced VDMS properties in LauchPad:
Program:
(u may not do this, it doesn't matter for running the game)
Close Dos Window on exit
Compatability:
EMS: 4096
XMS: 4096
IMPORTANT!!! BECAUSE OF THIS THE GAME HADN'T STARTED TO ME!!
SHUT DOWN DOSX!!! (Enable DPMI support) TURN IT OFF!!
everything else is by default..
i haven't touched anything else.. and the game runs perfect..😀
the game is v1.02
StrEagle
Reply 2 of 8, by DRECK
If you download this game from here: Underdogs
*link removed*
You can get this problem described in this thread!
"game doesn't run. hungs right after start. video mode seems to change, then nothing happens. when i press esc, cursor of random color appears in random place on the screen."
showthread.php?threadid=292&highlight=Krondor
Solution:
Edit the drive.cfg!!!!!
There are only two C!
Change the C to the right installation directory:
Maybe c:\bkrondor\
http://www.oldgamers.dk/showthread.php?s=&pos … 9466#post109466
Reply 5 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
Sorry Vlad,
Didn't know how to fix it with vdmsound and my expertise is with dosbox.
Water flows down the stream
Reply 7 of 8, by DosFreak
I'm sure Vlad will agree with me when I say that DosBox is increasingly becoming the better solution in most cases. M$'s NTVDM is a sorry piece of programming compared to DosBox and sadly VDMSound has to lay atop it like a slim pretty young woman atop a fat slob. 😮 Hey, that's a pretty good analogy!
Make your games work offline
Reply 8 of 8, by Nicht Sehr Gut
Originally posted by DosFreak I'm sure Vlad will agree with me when I say that DosBox is increasingly becoming the better solution in most cases.
So long as it doesn't require protected mode, or a 486, or a Pentium, or SVGA.
Plus it's still limited to basic 8Bit SoundBlaster audio.
A disturbing one, at least...
