Error in AbandonLoader
Reply 22 of 28, by vladr
Well, very likely you have some hardware (or hardware setting) that doesn't give you EMS. Try disabling USB support from the BIOS.
Cheers,
V.
Reply 24 of 28, by eL_PuSHeR
Rank Moderator
Moderator
Press <DEL> key when screen instructs you to do so. You may need to keep pressing it repeatedly before windows starts. WARNING: Don't mess with bios values if you don't know what you are doing. If you feel confident enough, press F10 key and Y key after making changes.
Reply 25 of 28, by Snover
Don't even bother, eL_PuSHeR. The number of questionmarks on that last message confirms to me that this person would never be able to touch their BIOS settings without completely fucking their computer. "Ooooh, I can make my CPU run at 2500MHz?!" (rated to run at 2000 for a REASON)
Yes, it’s my fault.
Reply 28 of 28, by vladr
Yeah thanks a lot. And how could I disable USB support? I use a USB mouse!
Windows will deal with your mouse independently of the BIOS. BIOS USB support is only for compatibility with old DOS versions (i.e. not the ones Windows uses).
V.
