VDMSound DOS path-> variable drive path?
General information and assistance with VDMSound.
Postby knarf. » 2004-11-04 @ 04:33
hmm difficult topic title lol I try to explain:
I want to burn my DOS games collections on CD
ofcourse I want them to run with VDMSOUND 2.1.0 (I have winXP)
before I burn I start the games once with rightclick -> vdsound, run wizard and remember settings
VDMSOUND creates a shortcut in the same dir so I can start my game with one click from now on..
BUT when I burn the games on CD, the drive letter changes if I run from CD, so the shortcut does not work anymore
is there a way to exclude the drive letter in the path and let VDMSound find it itself???? It would be very usefull
to explain where I am talking about, heres a screenshot:
(I use dutch winXP so don't mind the unknown words lol)
i.e. I want to run dos games with VDMSound directly from cd, I can make the shortcuts before burning..........so if I could make the path variable, it would work!!
I know I can change the drive letter to my cdrom station, but then it would only work on my desktop pc or my laptop but not on both ;)
thanks in advance,
frank
knarf.
Re: VDMSound DOS path-> variable drive path?
Postby MiniMax » 2004-11-04 @ 08:09
DOSBox 0.73 ReadMe | DOSBox Wiki | DOSBox 60 seconds guide | How to ask questions
_________________
Lenovo M58p | Core 2 Quad Q8400 @ 2.66 GHz | Radeon R7 240 | LG HL-DT-ST DVDRAM GH40N | Win 10 Pro
User avatar
MiniMax
Moderator
Location: Stockholm, Sweden, Europe, Earth Interests: Old games & young women
Postby knarf. » 2004-11-07 @ 02:44
first of all thanks but I already had a feeling it had to do with that..
I have to do something with the 'subst' commando??
can you enlighten how to use it with VDMSound pls??
C:> help subst
isn't there just a substitute command to address the dos path? like putting a *\games\blabla instead of d:\games\blabla
or a command so it directly looks in the directory you're in?
I thought '.' was it but that doesn't work with the vdmsound shortcuts
knarf.
Postby MiniMax » 2004-11-07 @ 15:37
  1. Define a virtual drive letter. V is good.
  2. Point V to the hard disk path, e.g
    Code: Select all
    D:> subst V: "D:\Games\Classics\Goblins\Goblins3"
  3. Create VDMSound shortcut using the virtual path, e.g "V:\Gob3.Exe"
  4. Burn everything to CD.
When you want to run it from the CD (drive X?), do a
Code: Select all
D:> subst V: "X:\path\to\goblins\on\cd"
before running the VDMSound shortcut.
Or something like that.
_________________
User avatar
MiniMax
Moderator
Postby vladr » 2004-12-06 @ 20:25
Yes, just manually replace "D:\...." with "." or remove the entire path if the shortcut is in the same dir as the .exe in the dialog you took in a snapshot. That should work and avoid any subst.
Also, once on CD, you can tell VDMSound to create shortcuts onto your desktop should you need to change ay settings later.
V.
User avatar
vladr
Postby kwerin » 2006-6-05 @ 15:33
    Code: Select all
Code: Select all
kwerin
Return to VDMSound General
Who is online
Users browsing this forum: No registered users and 2 guests
