Peixoto's patches for a few old games
Schedules and announcements about program releases.
Re: Peixoto's patches for a few old games
Postby blam666 » 2019-3-16 @ 13:07
@ Peixoto:
Alpha Testing NVIDIA Fix integrated in your patch in the future would be greatly appreciated (regardless if messing around with dgvoodoo or not). If it's easily done as you said (at least in TR3)... would just be a great and important improvement of the playability status of classic Tomb Raider games.
While some of the instances of the bugged textures remain predominantly aesthetic, the wretched invisible barbed wire thing really breaks gameplay to an extent in the already somewhat difficult levels of the games affected by this. You will just run into certain death at times, tiles below you that seemed "jumpable" will just result in unnecessary Lara kills & frequent frustration and so on.
But I will remain a patient Jedi pupil and wait for things to come, not giving in to the dark side of impatience and of annoyingly pestering patch/fix programmers in the meantime...
blam666
Postby Peixoto » 2019-3-23 @ 22:31
Hello there people.
I've been testing a lot a games in a effort to make this a program similar to DXWnd, with several tweaks you can apply to any game.
Its not sufficiently mature for a release yet and since i will have little time to work on this in the next months, i decided to release new "patches" for the games that already work.
There are 20 new games, forced resolution works in all of them, xBR filter woks ins all directdraw games but silver and texture swapping works in all 3D games but turok 1 and 2.
These are the new games:
Alien Earth
Blood 2
Darkstone
Diablo
Diablo 2
Die by the sword
Forsaken
Grim Fandando
Oddworld 1 and 2
onScappe
Outwars
Prince of persia 3D
Shadow man
Silver
Star wars - SOTE
Planescape torment
Turok 1 and 2
Tomb Raider I
Enjoy
User avatar
Peixoto
Postby blam666 » 2019-3-24 @ 23:39
Cool additions, great work!
I just checked my old copy of Pop3D, seems to run at first glance but I had to turn off Forced Resolution.
With FR turned on, the intro video defaulted to a black screen (only music playing) and crash after that.
Would a working FR allow me to play in custom widescreen?
blam666
Postby Peixoto » 2019-3-25 @ 00:08
blam666 wrote:Cool additions, great work!
Try this quicktime version:
https://1drv.ms/u/s!ApHOE-Ru-xkG5VRrqh6HSumF23x-
and do a clean install: uninstall, reboot, install
User avatar
Peixoto
Postby warm_wind » 2019-3-31 @ 12:36
Hello, I can't get tomb raider 4 to work. I have the GOG version.
It crashes on launch, saying that directx failed to setup.
I applied the multipatch.
Error log attached.
Thank you for your work!
error.log
(4.82 KiB) Downloaded 4 times
warm_wind
Postby Peixoto » 2019-3-31 @ 17:06
warm_wind wrote:Hello, I can't get tomb raider 4 to work. I have the GOG version.
Error log attached.
Hold shift to run the game's setup and see what happens
and update the program
User avatar
Peixoto
Postby warm_wind » 2019-3-31 @ 20:11
Program is already updated though?
I can access setup, but many resolutions are missing (1080p for example).
If I launch the game normally, without your program, it launches but crashes after the EIDOS screen. Also, setup gives all resolutions.
warm_wind
Postby Robbeasy » 2019-4-09 @ 11:01
Hi Peixoto,
Having an odd problem with your patcher
After downloading , double clicking on the help.exe just brings back a message 'Windows cannot access the specified device, path or file. You may not have the appropriate permissions to access the item'.
The very weird thing is that it then also removes the help.exe from wherever I have extracted it to - I don't know what it does with it...
I've tried to set permissions, run as administrator, extract to different locations - I'm a little stumped, any ideas as to why the help file won't open and removes itself??
D'uh!! Sorted it - was my anti-virus messing about with it, should have looked there first **embarrassed** - as you were :)
Robbeasy
Postby BladeDarkeden » 2019-4-16 @ 05:11
Hello Peixoto! My name is Blade Darkeden! Before I start, I just want to commend and thank you for making such an awesome patching system for these old games. Your work is helping to keep many of these old treasures alive. Now, on to the matter at hand. Just a few days ago, I updated the Patch and have come across at least 2 problems so far. The first lies with Tomb Raider The Last Revelation and Tomb Raider Chronicles. Everytime I go to play the game with your patch, it gives me a Failed to Setup DirectX error. I've tried everything from going through the setup for both games respectively to patching it with the Multipatch. I feel like the Multipatch would work except, everytime I replace the old exe with the new ones, it gives me a No CD Retry error (I have the Steam edition of the game if that tells you anything) which forces me to use the exe supplied by Steam. For the time being, I'm able to play these two games fairly well without the patch right now, so it isn't really a big deal, but I thought I'd let you know. The second problem is with Tomb Raider III. Ever since I updated the patch, everything appears zoomed in and set in the bottom right hand corner of the screen. I've supplies screenshots as well as the error log for you. I don't expect you to take care of these problems anytime soon, for I too am a very busy person, but if there's anyway you could give insight as to what is causing these problems, I would very much appreciate it! Thanks again, for all your hard work!
error.log
(5.23 KiB) Downloaded 3 times
Edit: I also tried Tomb Raider 2, Golden Mask, and the Lost Artifact and they're also acting up in the same manner as Tomb Raider 3. Plus Tomb Raider 2's fmvs are skipping automatically (At least the HQ ones) even though I have the K-Lite Codec Pack installed. Thought this might help in troubleshooting the issue.
Edit 2: If possible, do you think I could get the previous version of your patch until if this doesn't get resolved for a while? No pressure. Just thought I'd ask.
User avatar
BladeDarkeden
Postby MarkoftheWolves » 2019-4-18 @ 03:02
Whenever i try to launch the shortcut to Tomb Raider 2 that i created from the help.exe, i get an error message that says "C:\Games\Tomb Raider II\Tomb2.exe is not a valid Windows 32 or 64 bit program", i'm running the steam version on Windows 10 and have all the patch updates copied into the game files. Any idea what I should do Peixoto?
MarkoftheWolves
Previous
Return to Release Announcements
Who is online
Users browsing this forum: bellarmine and 2 guests
