Fasttracker 2.12 for MS-DOS
Reply 80 of 134, by 8bitbubsy
drastikterror wrote on 2020-08-30, 10:48:
Hello!
I was thinking about the possibility to implement a generic midi mpu-401 driver to make Ft2 work with external devices, in a way like Impulse tracker did with the command "it /s19 /a330"
Thank you!
As I have written in this tread before: I don't really know how to write low-level MIDI stuff, and I don't want to touch the low-level drivers used in FT2 without the proper knowledge... Sorry.
386:
- CPU: 386DX-40 (128kB L1 cache)
- RAM: 8MB 70ns FPM (overclocked to oWS)
- VGA: Cirrus Logic GD-5424 1MB ISA
- Audio: SB Pro 2.0 + GUS classic 1MB
- ISA PS/2 mouse card + ISA USB card
- MS-DOS 6.22 + Win 3.1
- MR BIOS
Reply 82 of 134, by traffkin
i could do that, but i'd need the full source code. disassembling would be not an easy task, time consuming and tedious...
drastikterror wrote on 2020-09-09, 10:55:
OK, maybe someone in this forum can help you, even without sharing the precious source code of FT2!
Reply 83 of 134, by 8bitbubsy
Well, are you fluent in Pascal and i386 assembler? There's also a lot of inline Pascal asm with hardcoded hex instructions because of limitations in Pascal for 32-bit asm instructions (FT2 actually runs in 16-bit protected mode). If you think you are up to the challenge and promise to not share the source code with other people, I can probably hand it over.
386:
- MR BIOS
Reply 85 of 134, by traffkin
i had quite good experience with both i could recall the stuff because of my great interest and involvement. as i said before, i use FT2 as my main sequencer/workstation, that's why i want it to be really useful and powerful even by contemporary demands. as for the source code, of course i promise not to share it in any case. i want to look into to find the possibility to add important features and i hope other users support my position and intention. let me know what do you think, and thanks in advance!
8bitbubsy wrote on 2020-09-11, 10:56:
Reply 86 of 134, by 8bitbubsy
I sent you the source code and a readme.txt file to explain how to use it.
386:
- MR BIOS
Reply 88 of 134, by traffkin
thank you!!! i'll look into it tomorrow and start to analyze possibilities. and of course will keep you updated!
8bitbubsy wrote on 2020-09-12, 10:33:
Reply 89 of 134, by thierry
Hello guys, I have a problem with the reproduction of a module, there is an instrument that does not sound, at minute 1:03, easy to realize, with other players it works, it is possible to see if it will not be something from my configuration or is something from the player, greetings
The party 1993 invitation , Trip To Heaven - WOTW
http://artscene.textfiles.com/music/mods/MODS … to%20heaven.mod
Reply 90 of 134, by 8bitbubsy
I hear nothing wrong at 1:03 (pattern 07) in FT2... Sounds the same in ProTracker.
386:
- MR BIOS
Reply 91 of 134, by thierry
It is strange, it can reproduce the error, Inertia Player fails too, Pattern 18 and above, FT2 win64 makes me the same fault, pro tracker ( win ) reproduces it well, the Dual Module Player ( DOS ) reproduces it well ,I would have to make a video, it shows like in a moment the note is cut off, i think Vibrato+Sample offset its the problem , because that's where you see that it cuts,Another error that I saw is that at the end of the module when it loops the module slows down, but the version that appears in the invitation to the 1993 party does not do that slow, but it is somewhat less, it is only the version of the module or some bad rip by modland
Reply 92 of 134, by 8bitbubsy
Aha, that's at 2:22, not 1:03. was too lazy to listen to the whole song, as I didn't know exactly what to look for. 😀
Anyway, that's related to a difference in how the 9xx (Set Sample Offset) effect is handled in the replayer. Remember that replayers are different across different players/trackers! Most .mod files were created with ProTracker (or NoiseTracker), with an exception of some coming from older or newer trackers.
ProTracker behavior (used for PT2 clone and OpenMPT in .mod mode, and probably XMPlay in .mod mode):
  • Non-looping samples: If 9xx is after the end of the sample, cut off note
  • Looping samples: If 9xx is after the end of the sample, start the sample from the loop start point (this is what should happen in the .mod in pattern 24)
FT2 behavior (also used for a lot of other replayers):
  • Looping samples: If 9xx is after the end of the sample, cut off note (this is what happens in FT2 in the .mod in pattern 24)
386:
- MR BIOS
Reply 93 of 134, by thierry
8bitbubsy wrote on 2020-09-14, 08:34:
Aha, that's at 2:22, not 1:03. was too lazy to listen to the whole song, as I didn't know exactly what to look for. :) […]
It is good to know, because very few reproduce well, will it be something that can be fixed or does it have to remain as part of the player?
Reply 94 of 134, by 8bitbubsy
It has to remain like this. The reason is that when FT2 loads MOD/S3M/STM files, it converts them to an XM module internally. FT2 has only one replayer, and if you bugfix it for better MOD-accuracy, it will suddenly be less accurate for XM (I care very much about extreme FT2 accuracy, so I don't touch the replayer).
386:
- MR BIOS
Reply 95 of 134, by 8bitbubsy
traffkin wrote on 2020-09-12, 16:34:
Any updates on this?
386:
- MR BIOS
Reply 96 of 134, by matze79
39.22 KiB
Fast Tracker 2 does not work with Dual Covox Plugs or any other Sort of Dual D/A Converters.
It also makes crackling sounds when playing MODs over single Covox Plug.
Co2 - for a endless Summer
Reply 97 of 134, by traffkin
working on this, trying to put filters into parallel buffer prior to mixing channels, not an easy task at all... some midi functionality will be added too
8bitbubsy wrote on 2020-09-30, 21:25:
Reply 99 of 134, by 8bitbubsy
Yeah, MPU401 support would be cool! Also traffkin, please be sure to send the code back to me if you manage to complete these implementations/fixes, so that I can continue with bugfixing in the future. I'm sure that there are more of the old bugs in there.
386:
- MR BIOS
