First post, by ViTi95
- Member
Hi everyone! I've been developing lately a new benchmark to test the bandwidth of old GPUs on DOS systems, given the knowledge adquired while developing FastDoom.
I'm releasing a pre-release version, this pre-release only tests write to VRAM transfers using 8-bit transfers, next releases will include more tests and more supported video cards. Bugs are to be expected on this release.
The supported video cards are the following:
- MDA
- Hercules
- CGA
- EGA
- MCGA
- VGA
- ATI Small Wonder series
- Plantronics ColorPlus
The release include two executables: V95_16.EXE is a 16-bit real mode executable (supports 8088/8086 cpu's onwards) and V95_32.EXE is a 32-bit protected mode executable (supports 386 cpu's onwards).
As always, the project is open source and you can take a look here: https://github.com/viti95/V95bench/
Download: https://github.com/viti95/V95Bench/releases/tag/0.0.1
