386DX40 build
Reply 121 of 434, by Markk
Old Thrashbarg wrote:
I believe some (maybe all?) of those Macronix chipsets have a small integrated cache. IIRC it's only something like 8K, but it's better than nothing.
You're absolutely right! I'm running speedsys on it, and it says 8kb L1 cache! However it performs well I think. The cpu scored 9.25 and the blue bar is beyond the 386DX-40 point.
Reply 122 of 434, by retro games 100
What does this mean, please people? 1MB Write Per Bit Simm Module. This SIMM stick can be seen here, on ebay.
I'm looking for some more 1mb SIMMs, for the Contaq 386 mobo, as featured in DonutKing's original post. The ebay seller has lots of them, and they are cheap. I could buy 4. The SIMMs have 9 chips on them. I just wondered what the "Write Per Bit" wording meant. Thanks a lot for any advice.
Reply 123 of 434, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Can only guess it should express DRAM - opposed to SDRAM which is written in bursts.
Anyway these are the sort of modules you are looking for. Maybe you should look after modules where the access time is mentioned though. You wouldn't want the slow slugs with 100ns.
1+1=10
Reply 124 of 434, by retro games 100
Hehe! Yes, you're right. I don't want any slugs in my machine. 😉 I could ask the seller what the speed is. Perhaps it's written on the chips, eg bla bla -100.
Reply 125 of 434, by Old Thrashbarg
Um... hate to burst your bubble here, but those modules won't work in your 386 board. You need 30 pin SIMMs for that, and those aren't 30-pin SIMMs. Actually, I'm pretty sure those modules are proprietary and won't work in anything other than an AST machine.
Reply 126 of 434, by retro games 100
Phew, I didn't buy any! Thanks a lot for pointing that out! 😀
Reply 127 of 434, by retro games 100
Some of my 386 bits have arrived, but I have made a mistake about the processor. I bought this one:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewIt … em=230394428942
Unfortunately, it's just a chip soldered to a hack-sawed piece of mobo. I can't actually use it. I need to get another processor. Can someone please verify that the following auction is OK to get - thanks a lot!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewIt … em=370301179337
Reply 128 of 434, by Mau1wurf1977
Wow that's rich...
The other auction looks fine.
Anyway what's the difference between the plastic and ceramic AMD cpus?
Reply 129 of 434, by Markk
Some of my 386 bits have arrived, but I have made a mistake about the processor. I bought this one: […]
wow, I didn't see that. I also bought one as I thought it was a nice price.... 😳 That is not good at all. The seller should mention that it's a cut piece from a m/b, as there are also a lot of 386/40 cpus that are soldered on a small board that underneath it has pins to place it on a PGA socket, and are very similar if you look on them from up above.
Reply 131 of 434, by Tetrium
What a lowlife scam -_-
And to think he may have gotten more for it selling it as a complete mobo.
He deliberately cut the cpu out to make it look as much as the original thing, then deliberately leave out the important bits.
Even sais he'll ship in antistatic packaging 😒 .
Edit: You have to be so careful with what you want to buy. I think everyone's made at least 1 bad purchase there.
I had a minor one, I was looking for 24pin 2 20pin ATX psu adapters as I'd bought a couple 350W FSP psu's new for a good price. But they have a 24pin connector which often won't fit on the (older) motherboards I had planned to use them on.
So I bought the adapters but didn't pay enough attention.
They were the right adapter, right, but the 12V wire was so ultra thin, theres no way I'm gonna risk using those adapters. With the current going through a thin wire, it'll probably melt or cause other kinds of havoc.
Another story, I once saw a veeery interesting chip for sale in the US. Noone was bidding on it and postage was just $10.
BUT...right before I bought the item, I double checked how much he'd ask for overseas shipping. $80 BUCKS!
$80 dollars for postage cost what normally would be more like $10 or less.
Another time I saw another veeery interesting chip for sale, the POD for Socket 4!!!
The seller seemed absolutely sure it was for Socket 4, so I asked him for a pic of the underside, received the pic, counted the pins and it was the MUCH more common (and thus, much cheaper) Socket 3 one.
But at least I haven't received any bricks yet 😜
Reply 132 of 434, by retro games 100
I've got a confession to make. It's not easy saying this. I bought 10 of them. 😢 😢 😢 😢 😢 😢 😢 😢 😢 😢
I thought "get 10, and 3 won't work, so that leaves 7. I can do some mad experiments on 2 of them, which will leave 5. I can put 3 of them in to machines, and have 2 as back ups." Or something like that anyway.
Here's a photo of my waste paper basket.
Reply 133 of 434, by Old Thrashbarg
I really don't see anything wrong with what he's doing... I mean, I'm sorry, but it's quite obvious from the picture that it's a cut-out chunk of board, and I see nothing in his description to represent it otherwise.
That's not to say that none of those sorts of sellers are scammers, but cutting out a piece of a board really isn't an uncommon thing for chip salvagers to do. It's a lot easier to ship QFP chips while they're still attached to something, since the pins are so delicate. Those sorts of outfits aim more at electronics hobbyists and chip collectors. The hobbyists can desolder the things for reuse, and the chip collectors usually don't want the full boards.
Reply 134 of 434, by retro games 100
The seller's photo looked similar to the CPU in Donut King's original post. If the seller had included a photo of the underside of the CPU section (to show no pins!), then there would be no misunderstanding. It would be very obvious the chip had been hack-sawed away from a mobo, and not a chip to use in a CPU socket. I think the seller should have made the item photo more clear. I am not knowledgeable about 386 hardware.
Reply 135 of 434, by Alphakilo470
Sorry to hear about your bad luck. I don't think it was an outright scam; maybe his description just needed a small amount more detail. Apparently, there's a market for scraps of this sort. There's just no such thing as being too careful when buying off the internet.
You know, seeing this post, for some reason, reminded me that I have an old 20mhz Intel 386 laying around somewhere. I know I have some 30-pin simms in a box somewhere as well. Maybe I should hunt down a motherboard.
Reply 136 of 434, by Tetrium
Dammid...
Well, let me put it this way...I didn't buy just one of those psu adapters either -_-
Well, perhaps you could still sell them on www.cpu-world.com?
Even if they're cut out of a pcb, if it's somekind of uncommon stepping, you could even get your money back 😉
www.cpu-world.com is full of chip collectors who'll desolder chips like these and put them up for display.
It's also a good source of chips as theres always sales going on.
You just have to let them know you want the chips intact, or at least so it looks to be functional, as they'll be selling them untested.
A plus is, it won't matter much for you if a chip has some scratches or part of the print is missing --> lower price ;D
Reply 137 of 434, by Tetrium
In RG100's defense, writing you'll be sending them in antistatic packaging suggests these are working units...
Reply 138 of 434, by Markk
I totally agree with you. Furthermore, when you say " Do not tested, So sold "AS IS" " I think it means it may work or not. Well, in this condition it certainly won't work.... Also he says " It is used and on board ". In order to be correct, he should replace "on" with "cut from a". And I would strongly suggest to change his nickname to retro_mobo_butcher.
Reply 139 of 434, by Old Thrashbarg
It was an unfortunate misunderstanding, but hopefully you've found the lesson to take away from it.
If you don't know much about something, it becomes that much more important to do a little research before buying ten of them. Making assumptions is never a good idea, especially when it's an unfamiliar subject.
The seller could've made the photo more clear, maybe, but you could've also looked closer at the photo given. The ragged edges and half cut-off numbers aren't difficult to spot, and would be enough to give me pause even if I thought it was an adapter board. You could've also asked questions... either to the seller or here.
They probably are working units. The fact that they're attached to a piece of non-working board does not preclude the chips from being usable. You forget that there is a whole class of hobbyists and electronic techs out there who see no big issue in pulling a surface mount chip off one board and soldering it onto another.
