Huge 286 tower found
First post, by Half-Saint
Another dumpster find, picked it up hoping for a Pentium Pro since it's a really really tall case. It just barely fits under my desk as it measures 63cm high.
It turned out to be a Headland 286-16 with coprocessor, 1MB onboard + 4 empty SIMM sockets. Graphics probably Hercules (installed a Trident 512K), HDD/FDD controller, one 5,25" floppy and a 112MB WD hard drive (amazingly no bad sectors).
It was used either by a HAM radio club or a HAM radio operator. Plenty of HAM radio software left on the hard drive, no games tho.
Will try to take a pic tomorrow. The case is also quite nice, only slightly yellowed.
Reply 3 of 37, by sliderider
Jorpho wrote:
SIMM sockets on a 286? I never would have thought. What would you do with them?
Yup. I bought a board from artifact systems a while back that had them. They are only on late production 286 boards, which is probably why a lot of people have never seen them. Boards that have them usually also have a 16, 20, or 25mhz 286 installed and either a Headland or C&T chipset.
Reply 5 of 37, by Robin4
I think the later boards do.
Reply 6 of 37, by Half-Saint
Jorpho wrote:
Unknown_K wrote:
You can install up to 16MB on a 286 and 386/SX.
Well, sure, but what would you run on a 286 that could use that much RAM?
Some games took advantage of extra memory.
Reply 8 of 37, by sliderider
16mb on a 286 is a bit extreme. I can't see having that much as being very useful except if you wanted a massive RAMdisk for lightning fast access times. 4mb is probably more than enough for a 286 system.
Reply 10 of 37, by Anonymous Coward
How about 16MB in an original 5170? Is that being too extreme? 😎 (It's actually 16.6MB, with the last 6MB as EMS)
Reply 11 of 37, by Unknown_K
For gaming 4MB was more then enough for a 286, but you have to remember nobody purchased a speedy 286 for anything but work back then. Gaming was something you did after the work was done.
A 286 is a 16 bit CPU that can only address 16MB (same as the 386 SX). Anybody loading up RAM back when was doing some serious database , spreadsheet, server, or CAD work.
I think I have one generic 286 motherboard with 4 SIMM sockets (286-16 or 20), and a few PS/2 systems that can take RAM upgrade cards )or SIMMs in a Model 30-286).
Reply 13 of 37, by pianoman72
Jorpho wrote:
On a 286? Can you name some? I am genuinely curious.
I remember two Event Horizon games that could use more than 4mb of EMS ram, The Summoning and Veil of Darkness. They perform well on a fast 286.
Reply 15 of 37, by Half-Saint
Added pics. How do you make the inline photos visible without having to click on the link?
On another note, how do you feel about a Sound Blaster Vibra 16 CT4180? It's the oldest card I've got...
Also, check this out: Re: post up pics of your "computing area"
550.89 KiB
No downloads
Reply 18 of 37, by Skyscraper
This system should be in your keep list.
It looks like it is in great condition.
