First post, by Artex
- l33t
For this week's build I thought I'd spice things up a bit instead of doing another "insert year here" build like I've done the last few weeks. I dug through "Mt. Retro" in my basement and uncovered two brand new, never been touched Asus P3B-F motherboards still in their original boxes. Now I know I've already done a build based on the mighty Intel 440BX chipset, but letting a board of this caliber just sit there unused is a travesty IMO!
On to the processor... My 1998 box used a slot 1 PII-450 and I do have a PIII-450 slot 1 I could throw in there but... bah... too boring and not different enough for this one. And then I unearthed an awesome little piece of hardware - an Asus S370-DL slotket that I picked up in a rummage sale last year, still in its original box! Discovering this little guy now opened up some more possibilties for processor choices since I now could use a socket 370/FC-PGA chip! I opened up my box of processors and saw one Pentium III that I completely forgot about - a pin-modded Tualatin 1.4 Ghz-S chip that I picked up off eBay over a year ago....
The processor can be used in the slotket (when set to use the default CPU voltage), and using a combination of the latest Asus P3B-F BETA Bios and a little FSB bump to 133, this puppy should (according to others) work just fine. The issue is that the FSB overclock pushes the AGP bus speed to 89Mhz as a result of a 2/3 divider - a speed that not all graphics cards can hang with - including my own it seems.
I tried a Ti4200 and then a PNY Ti4600 to really max it out (and just look at that color!!!), but at 1400Mhz/133/33.25 the system is unstable and randomly locks up during 3D benchmarking. It does seem stable at 1300Mhz/124.0/31.00. I swapped out my generic 256MB PC133 DIMM for a Crucial 128MB PC133 DIMM but I still observed the same behavior at 133Mhz FSB so for now I'll leave it a 1.3Ghz with the FSB @ 124Mhz while underclocking the PCI bus a bit at 31Mhz.
Since my stash of IDE drives is getting low, I thought I'd throw in a PCI SATA controller, hooking it up to a 2.5" 7200 RPM SATA drive to maximize performance. I could NOT get the system stable with this thing, observing random lockups and other odd issues (drive itself is fine). I don't know why it didn't work - the PCI bus speed remained 33Mhz while pushing 1400Mhz - but I ended up throwing in a 250GB Western Digital IDE drive instead and it worked fine attached to the board's native controller.
The fan on my existing S370 CPU cooler was making a god-awful noise, so I picked up a Startech 1U CPU cooler and WOW - what a difference, both in performance and WEIGHT. This thing is a heavy SOB but dropped temps pretty dramatically - my only complaint is that it's a little loud, but totally tolerable.
Couple of other weird things...
1) Despite being a Pentium III, the post screen still shows Pentium II
2) It sometimes boots up at 700Mhz and takes one additional reboot to run at 1400Mhz.
Case: Enlight Enlight EN-7237 (4-Bay)
Power Supply: Corsair CX430M partially modular PSU
Motherboard: Motherboard - Asus P3B-F (Intel 440BX) Rev. 1.04 using 1008 BETA 004 BIOS (1999)
Processor: Intel Pentium III-S 1.4Ghz 1400-512-133 FCPGA2 Socket 370 (Tualatin) (SL5XL) (Pin-Modded) (2002)
Cooling: StarTech FAN3701U 60mm Ball CPU Cooler Fan w/ Copper Heatsink & TX3
Network: 3Com 3C905B-TX
Storage:
Western Digital 250GB 7200 RPM IDE
3.5" Floppy Drive
DVD-ROM SD-M1502
Memory:
1x256MB PC133 6NS 3.3V NON ECC SDRAM
Audio:
Creative Sound Blaster AWE64 Gold ISA
Video:
NVIDIA GeForce4 Ti4600 - PNY VCGF4TI46PB 128MB AGP (NV25) (2002)
Onto the hardware Pr0n!
The guts...
The case..
Pin-modded Tully!
Temps
3DMark 2001 SE @ 1.3Ghz
Benchies @ 1.4Ghz
CPU-Z @ 1.3 and 1.4Ghz
Asus P3B-F Motherboard
Asus Slocket
Beefy Cooler
