First post, by FFXIhealer
So I have a few LGA775 systems lying around. I got this Micro-ATX LGA775 motherboard from a buddy after we upgraded him to a new Ryzen 5 6-core/12-thread gaming rig. Yeah, it had a dual-core Pentium in it running around 2.4GHz. But recently I got into running PLEX on my computer at home and I've spent the last 3 weeks ripping DVDs onto my 3TB hard drive. Still going strong with my anime collection right now. Anyway, I was thinking "Hey, didn't Phil's Computer Lab do a video on modifying an LGA771 Xeon to work on a 775 board? Isn't it supposed to be cheap?" So I was like "Hey, let's try that sh*%!"
I just got the adapter stickers today. I modified the CPU package to go into the socket without having to cut the tabs off the socket itself over a week ago with a dremel tool. I also hacked the BIOS to add the microcode myself and then reflashed the MB around the same time.
Current build:
ASUS P5G41-M LE [LGA775, Micro-ATX]
Intel Xeon E5450 [3.0GHz, 12MB L2, 1333MHz FSB]
4GB DDR2-800 (2x2GB G.Skill)
No discrete graphics card
No discrete audio card
500GB Seagate Barracuda 7,200RPM SATA
3TB Western Digital GREEN SATA (pulled out of a MyCloud USB 3.0 enclosure that had questionable reliability)
Ubuntu Server 18.10
Plex Media Server
Samba File Shares
I've spent the last 4 hours messing around with this. Having a blast - also frustrating as all hell. But very satisfying.
The idea was that when the WD Green drive was connected directly to a computer via SATA, the drive was 100% functional. But all the data was encrypted by the USB 3.0 controller card in the USB enclosure. So first I had to get that drive to power on successfully with my computer, then dump all of the files to my 3TB drive, then rip the drive out of the enclosure and stick it in the Ubuntu server box, change the DOS file system to GPT, create the 2.7TB partition, format it ext4, then place it under /data. Then install Samba, create the user accounts, passwords, document everything, get the shares in place... dump the files back to the server (which I'm currently in the process of doing as I type this), etc. Then I gotta worry about migrating my PLEX server off my desktop and onto the server. I've already tested out streaming and the vast majority of my content was encoded h.264 and there was more CPU hit on my network drivers than there was on the PLEX process, so I'll assume at this point that it doesn't have to do anything to the files while streaming to my TVs in the house.
This should be VERY EASY on this quad-core Xeon. I'm really only asking it to be a file server and a PLEX media server.
Doing this is getting me really hype and I wonder if I'll be able to go to sleep at the appropriate time...
Reply 1 of 2, by Private_Ops
I at one time had one of those exact CPUs in an HP motherboard (HP Pro 3000, G45/43 chipset I think).
Was fun to experiment with. In the end it was replaced by a Wolfdale E6600 and relegated to Pfsense duty.
Reply 2 of 2, by FFXIhealer
I know there's a lot one can do with a server, but my problem is I really have no need for anything else. It's like "Cool, you can do your own private e-mail server!" Yeah, if you wanna pay some company monthly fees to be able to publish and host your domain name credentials so that the e-mail server actually works. "Well, what about hosting a web server?" Again, same publishing fees, but now it's like - what the hell do I need a web page for? What moronic garbage would I post to it that nobody else in the entire world cares about or wants to see? I mean, this is why MySpace died.
Anyways, so I got all of my media files transferred to the server and PLEX set up once again. It streams very well all the regular 480p content. So I went to try one of my two blu-rays (1080p). TRON (classic) started off just fine for about 20 seconds, then the video just halted while the audio continued. The screen looked like it was stuck on the opening graphic montage. I skipped ahead to the 2nd chapter and it was perfectly fine.
I tried my 2nd blu-ray movie, Star Trek (2009). The movie played perfectly fine except for near the beginning during the ship fighting, there was glitched graphics with a bunch of squares all over the screen for about a second before it went back to normal. It was the only thing I saw like that. Streaming either file onto my gaming rig with 1080p monitors showed neither of these errors. I wonder if it was because I had tried streaming it to my PS3 which is connected to a 720p TV...possibly an issue with the transcoding? I don't know. I was hoping the PS3 would adjust the video itself for the lower-res screen, not the PLEX server.
But hey, this is why we do things like this, right? We love working on problems like this.
