Evolution of a Socket3 System to a POD @100MHz
Reply 80 of 82, by PC-Engineer
Your described problems pointing to an issue with L1:WB in combination with DMA access. This was a common problem in 486 platforms with introducing of WB-CPUs. The WB-mode needs a tight management of changed and writen adresses in RAM and caches. A two layer WB-mode (L1+L2 in WB) in combination with a component, which writes into the RAM in parallel to the CPU and the cache line (called DMA) is not easy to manage. The world of 486 were early pioneers ...
1994/1995 - Socket3 - ASUS SV2GX4 / POD 100MHz / 64MB / SCSI - Windows 95
Reply 81 of 82, by PC-Engineer
feipoa wrote on 2019-12-28, 21:01:
No I don't, sorry. I thought SV2GX4 had the greatest potential for L1:WB?
There may be another user here, who has a board with SIS 85C471 + POD + L1: WB + Adaptec SCSI in use and can give us the hint ... please! 😀
Reply 82 of 82, by shock__
Hate to bump this thread but could anyone of you SV2GX4 owners check whether your board works with a POD and a GUS (Max or PnP) for Duke3D/ROTT/Raptor? Duke and Rott have issues with Midi, while sounds work fine. With Raptor it's the other way around.
I have a SV2GX4 Rev 1.7 here which butchers the sound for above games whenever I try to use the GUS with my POD83 - so far the only fix I found was disabling L1 cache altogether.
Also noted that CTChip hangs when attempting to fix the dirty-bit whenever I have 1024K L2 cache installed - however it works fine with 256K in place. I'll check the modified BIOS later today.
Current Project: new GUS PnP compatible soundcard
[Z?]
