Made in USA 386 with Media Vision PAS16
Reply 40 of 76, by Caluser2000
If you really want help you need to answer these questions. A bit like a customer wanting to have his/her IT guy to solve an issue back in the early '90s.
Reply 42 of 76, by Caluser2000
Intel486dx33 wrote on 2020-11-28, 19:05:
I think the motherboard bios is bad. I am going to have to get a new 386 motherboard.
What gives you that idea exactly?
Reply 43 of 76, by cyclone3d
And even if the BIOS is bad, why not get a new BIOS chip, program it and install it?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 44 of 76, by Intel486dx33
Actually, I have been looking for another motherboard because this one only has 64kb cache.
But I will trouble shoot this motherboard some more and try to figure out why it is not detecting IDE hard drives.
Reply 45 of 76, by rmay635703
Intel486dx33 wrote on 2020-11-29, 09:54:
64k is doing well for a 386, a few have 128k but it seemed like only hybrid boards or IBMs had the full 256
Reply 46 of 76, by Caluser2000
For an 386SX mobo that is quite a reasonable cache. Try and sort you hdd issue out first.. If you don't know what you are doing get someone local to help you.
Reply 47 of 76, by Anonymous Coward
rmay635703 wrote on 2020-11-29, 18:37:
Pretty much all the hybrid boards did 128k or 256k, but quite a few true 386 chipsets supported 256kb too...not always in the first revision however. They were less common, but not impossible to find.
Reply 48 of 76, by Caluser2000
Anonymous Coward wrote on 2020-11-30, 14:00:
We are talking about a 386SX here.
Reply 49 of 76, by Intel486dx33
149.97 KiB
Well, I am trying to build a good 386 multimedia computer with 16mb ram, CDROM, and sound card.
I want it to play DOS games in best playback quality.
So I want a math-co processor too.
Win3x uses allot of ram too.
I currently have it setup in this Nice Aluminum Lian Li case until I can find an appropriate case.
I also want to be able to slow it down to 12mhz 286 speed if possible. So I will run it at 33mhz speed by default.
Reply 50 of 76, by Anonymous Coward
Well, that is not 100% certain. If you look at the first page of the thread a second 386 board is shown which is a DX. The author stated his board had 64kb cache, while the SX board shown clearly has none.
Reply 51 of 76, by Intel486dx33
My goal is to get the most out of the 386 CPU and also be able to down clock it with no problems.
For best game play.
I am really not trying to be period correct. And I am trying to eliminate any bottle necks.
Reply 52 of 76, by Caluser2000
Anonymous Coward wrote on 2020-12-01, 00:32:
If you read the whole thread the OP flip flops all over the place as he usually does, doesn't respond to legit questions to try and help him out and comes out with some unrelated post afterwards.. Also he claims to have been an IT tech in the early '90s yet he is absolutely clueless about that era kit and how to sort them out.
Reply 53 of 76, by Intel486dx33
This 386 computer looks stunning like a Mac Pro.
Reply 54 of 76, by Intel486dx33
The hard-drive became corrupt and gained a bad sector so I had to reformat it and reinstall everything.
It is working fine again.
There is NO way to disable cache in bios. So I have to use the Setmul utility.
And disable L1 cache this way. But it does nothing. And turn off the turbo switch only slows down the CPU to a 386sx@20mhz.
I was hoping to go as slow as a 8088 CPU.
My 486dx4@100 can go as slow as a 286@20mhz.
I know I was able to slowdown a computer to a 8088 buy I dont remember which computer it was ?
Has anyone had success doing this ?
Reply 55 of 76, by Intel486dx33
I am going to work on this today.
Maybe play around with different sound cards.
I will benchmark it today.
Reply 56 of 76, by Intel486dx33
More benchmarks.
Reply 57 of 76, by Intel486dx33
Anonymous Coward wrote on 2020-08-02, 14:11:
I really like the look of the Model 40SX. A proper full height desktop case. It looks like a microchannel system, but it takes ISA cards!
Yeah, I like the looks to but I don’t like the proprietary hardware and bios thats why I went with a third party IBM compatible.
Reply 58 of 76, by Intel486dx33
Plays Wing Commander 2 very well.
Reply 59 of 76, by Intel486dx33
More photos:
