IBM Aptiva 2176-352 build
Reply 20 of 33, by soupapes
Limpem wrote on 2021-11-20, 12:36:
Well I did some testing and can confirm I have your issue as well on this board. None of the 3x modi seem to work without a bios […]
None of the 3x modi seem to work without a bios error:
150 Mhz (50Mhz)
165 Mhz (55Mhz)
180 Mhz (60Mhz)
200 Mhz (66Mhz)
If you don't mind ignoring the error every boot, the processor will probably work fine at 200 Mhz just as the 233 Mhz works fine on other boards which also cause an error on boot.
You could test it by running cpu-z in Windows and see the reported speed.
I didn't want to do a fresh install to see for myself 😉
If you want to verify if you have the FRU12H2015, it was reported on a sticker above the 2 SIS chips on the mainbord.
Hi, thank you for your help.
You have the same board as I, and you got the same results.
I was able to use the settings for 166MHZ, so I guess I will keep this way, since I do not like having the error every time the machine boots.
I have updated the firmware to early version from dated from 99.
    101.07 KiB
    97.89 KiB
- IBM Aptiva 2176
- Unbranded 486 DX2 66MHz
Reply 21 of 33, by soupapes
Limpem wrote on 2021-11-20, 12:39:
I also did an additional test with a 200 Mhz pentium Overdrive. The bios didn't give any error messages, but also didn't report […]
The bios didn't give any error messages, but also didn't report the clockspeed.
Instead it just said Pentium ODP.
So if you want a 200Mhz error free boot process (and also extra cpu power + MMX instructions) you might consider this cpu if you can find it cheap.
Interesting. I guess I'll try to find a cheap one in ebay 😀
Thank you.
- IBM Aptiva 2176
Reply 22 of 33, by soupapes
So this is the current status of my build.
Decided to use an SDCard to IDE adapter with 8GB SD to be used as primary unit, and not to use the hard drive. It works great with Windows 98 SE.
Installed this NE2000 ISA network card, and replaced the MWave Audio/Modem with a Sound Blaster 16 card.
    127.33 KiB
    135.01 KiB
    86.79 KiB
- IBM Aptiva 2176
Reply 23 of 33, by soupapes
Also tried this USB2.0 PCI card with two ports, to use with a Zip100 USB drive, but windows 98 becomes very unstable and frequently freezes, so decided to remove it.
I will try later a different branded USB card that I should have in my spare retro junk.
    122.06 KiB
- IBM Aptiva 2176
Reply 24 of 33, by soupapes
I had a spare 5.25 floppy drive, so I throw it in the case.
I think it looks cool.
    24.47 KiB
- IBM Aptiva 2176
Reply 25 of 33, by Limpem
soupapes wrote on 2021-11-20, 14:02:
Thank you.
Sweet, but don't overspend!
Overdrive pentiums are usually quite expensive when I see them on ebay.
If you do want to buy them, it might be cheaper to upgrade the motherboard and use a regular pentium mmx cpu.
The boards I can recommend:
1st pick is the 93H4690 (which is what I currently use).
Although it is meant for a totally different system (IBM PC 330) it works perfectly in the aptiva (I did have to unscrew one of the mounts for a serial port for installation).
The advantages over your current board:
-intel 430HX chipset (still 64MB limit though)
-S3 trio 64V+ onboard graphics, which have one of the best dos compatibility
-Works fine with the 233MMX (shows as 100Mhz in bios, but no boot errors)
-Normally functioning pci ports, the Aptiva boards have some limitations with certain pci devices (TNT2, savage4, voodoo 5500 and other cards don't properly work on aptiva including the second pick, but they work fine on this board)
-Option to upgrade the riser board to a 60H9503 which gives 5x PCI and 3x ISA
The disadvantages to the second pick:
-No SD-Ram support
-No overclocking
-233Mhz cpu reported incorrectly in bios, but fully functional
-I never tried any official Aptiva install media, but it probably won't work on this board
-(very specific for my case) the ps2 mouse from my kvm switch isn't recognised by this board
2nd pick is the 93H77122
-Intel 430VX chipset
-Is an Aptiva mainboard and uses the same chipset as the 2176 A2 board, therefore my Aptiva install media worked with this board installed
-Ati 3D Rage II+ onboard graphics
-Works with SD-Ram instead of EDO Ram and EDO DIMM which grants a minor speed improvement with my testing
-Fully supports 233MMX Pentiums with correct clockspeeds in BIOS
-Overclocking to 75Mhz Bus (couldn't get it stable with certain hardware unfortunately)
Both those boards will require a voltage regulator which isn't needed for your current board.
In the pictures I included are both the Pentium and Pentium MMX boards.
The one on the left is for the Pentium MMX cpu's and the one on the right is for regular Pentiums.
Make sure the one suitable for your specific cpu is included if you order a motherboard as an upgrade (or order one seperately).
PS, I love the larger floppy drive! Other hardware seems nice as well 😁
    443.15 KiB
    880.49 KiB
    563.27 KiB
    517.05 KiB
430HX/P1 233MMX/64MB/S3VirgeDX,Voodoo1SLI(King Shaman)/AWE32
440BX/CelTualatin1400/512MB/Banshee, PowerVR PCX2/AWE64Gold
645DX/P4Northwood 3,5Ghz(Oc)/512MB/Voodoo5500/Vortex2
875P/P4EE 3,4Ghz/1GB/GeforceFX5950/Audigy2ZS
Z97/i3-4370/16GB/GeforceGTX960/X-Fi
Reply 26 of 33, by soupapes
Limpem wrote on 2021-11-20, 15:33:
Sweet, but don't overspend! Overdrive pentiums are usually quite expensive when I see them on ebay. If you do want to buy them, […]
Thank you.
-No SD-Ram support
-No overclocking
Nice collection of hardware you have 😀
Here in Europe it is very hard to find this kind of components for sale, and usually they are quite pricey. But if an A2 board shows up for sale at a decent price, I'll take it.
- IBM Aptiva 2176
Reply 27 of 33, by Intel486dx33
soupapes wrote on 2021-11-20, 13:37:
Is your Aptiva a 2176? Does it has USB port (modern version of the board)? Can you confirm what version of BIOS do you have? An […]
Intel486dx33 wrote on 2021-11-20, 13:25:
Those are my two favorite IBM computers. The PS/1 and This Aptiva. My Aptiva has a 200mhz Pentium CPU in it. And is running Win9 […]
soupapes wrote on 2021-11-16, 14:40:
So today I received a lovely Aptiva I bought from eBay. It was one of my dream machines when I was a young boy, after having as […]
It was one of my dream machines when I was a young boy, after having as my first computer an IBM PS/1 486 😀
It's a Pentium 120MHz with 48Mb ram and 1.2GB HD.
I am planning to do the following upgrades:
- 3DFX Voodoo 4mb PCI
- Intel P200MHz CPU
- additional Hard Drive
- Replace MWAVE sound card with a Sound Blaster
- Install windows 98 SE
The BIOS of my machine comes in spanish, but I haven't found a menu option to change de language. Anyone knows how to do it in this machine?
Also tried a 10Gb hard drive, but the BIOS only supports up to 8.4Gb. Is there a recent BIOS update capable of solving this?
Greetings from Portugal!
And is running Win95 the Operating system that came with these old Aptiva’s.
The Pentium 120 is actually fast enough to play most DOS games and Win95 games.
32mb is actually all you need for DOS and Win95.
1.2gb hard-drive is also more than BIG enough.
Maybe add a second drive to store all your files.
Any chance you could send a picture of how the board jumpers are set next to the CPU (JP10 & JP11)?
See my posts:
IBM Aptiva c77 restore.
Reply 28 of 33, by soupapes
Received today this Primax speakers I found for sale online.
They should be period correct for this build.
    114.84 KiB
- IBM Aptiva 2176
Reply 30 of 33, by Limpem
Now that's a sweet combination!
As for aptiva parts in Europe:
I'm from Europe myself, I got most parts from Italy, Poland and the UK (pre-brexit) through ebay.
They're not as common as in the US, but they do come around eventually and usually aren't very expensive. 😀
Oh, and when you switch to one of the Intel boards, you will also get at least one USB port (I think usb 1.0 or 1.1 though if you need 2.0)
Reply 31 of 33, by soupapes
Limpem wrote on 2021-11-25, 11:59:
Now that's a sweet combination! As for aptiva parts in Europe: I'm from Europe myself, I got most parts from Italy, Poland and t […]
Actually, the Voodoo card came from Italy.
Before Brexit I bought a lot of stuff from UK, but now the packages are retained in customs and I have to pay 23% extra of import taxes.
I found a lot of good stuff in US at decent prices but the shipping costs to Portugal are insane.
- IBM Aptiva 2176
Reply 32 of 33, by soupapes
So today I installed the voodoo card.
Windows 98 SE detected it and automatically install a driver. In the windows display properties I don't seen anything new to configure or define settings for the voodoo. Is that expected?
Do you recommend me to install any particular software or different driver for the voodoo?
- IBM Aptiva 2176
Reply 33 of 33, by soupapes
soupapes wrote on 2021-11-27, 13:48:
Downloaded this driver from PhilsComputer Lab:
voodoo_graphics_driver_kit_version_3.01.00.zip
It seem's better than the default driver from Windows and now I have access to 3dfx tab in display properties.
- IBM Aptiva 2176
