An EPIC Single Socket-8 Build
Reply 100 of 152, by kixs
Q3A needs 64MB of memory. Does the HDD get accessed a lot while running DEMO? I would guess you won't get any more FPS with 768MB - maybe 1 or 2 at best.
Reply 103 of 152, by Irinikus
I've just committed to purchase this Gravis Ultrasound plug&play version 3 + disc's + CD + 2MB memory for the machine: (It will be slotted in below the AWE64 Gold!)
My Collection
YouTube
Reply 104 of 152, by kixs
This is quite an amazing built. I see there is no upper cost limit 😉
PS:
Always nice to see someone making an effort to finalize his built 😁
Reply 106 of 152, by Irinikus
kixs wrote on 2023-01-24, 20:07:
PS:
Thanks man! 😀
My Collection
YouTube
Reply 107 of 152, by Irinikus
maxtherabbit wrote on 2023-01-24, 20:55:
Irinikus wrote on 2023-01-24, 13:52:
Here's Quake II @800x600: […]
thanks, how about 1024x768?
Here you go:
My Collection
YouTube
Reply 108 of 152, by maxtherabbit
Irinikus wrote on 2023-01-24, 21:06:
Here you go: […]
Here you go:
very nice score!
Reply 109 of 152, by TheMobRules
Irinikus wrote on 2023-01-24, 16:14:
Very nice!! Looks like that GUS is in great shape!
If you have the time, could you try to image the driver floppies for archival purposes? A simple tool like DSKIMAGE will do the job.
Reply 110 of 152, by Irinikus
TheMobRules wrote on 2023-01-24, 22:23:
I will do, once I have them in hand.
My Collection
YouTube
Reply 111 of 152, by Irinikus
maxtherabbit wrote on 2023-01-24, 21:39:
very nice score!
Thanks! 😀
I’m very happy that the system’s giving me the performance that I expected! (It’s at least been money well spent!)
My Collection
YouTube
Reply 112 of 152, by Irinikus
After some thought I think that I might actually fit the GUS into my fourth-coming Dual Pentium Pro build, as this current build is running XP Professional and the Dual Pentium Pro is set to run NT4!
As I unfortunately cannot find an appropriate XP driver for this card!
This Dual setup also needs some interesting features! I plan to give it a dual Voodoo2 SLI setup with the Dynamic Pictures Oxygen 202 as a 2D card, a SCSI RAID card and maybe this GUS!
My Collection
YouTube
Reply 113 of 152, by PD2JK
My compliments to your not so obvious choice of hardware, nice photo's.
How about the case or housing for all this exotic stuff?
i386 16 / AMD DX4-100 WB / Pentium MMX 200 / BP6 Dual Celeron 433 / Athlon Orion 700 + TB 1000 / PIII-S 1400 / AthlonXP 1700+ / Opteron 165
Reply 114 of 152, by Irinikus
You may think that I'm crazy, but I may end up considering one of these cases for this Dual Pentium Pro build, as it will show off the hardware nicely. (Especially if off-white in-case lighting is used! NO RAINBOW COLOURS!!!!)
It has the right number of card slots to accommodate this mother board. (A mixture of the old with the super modern!!!)
I would have to make up a custom mother board holder to interface this AT board with the ATX mounting points in this case. (A piece of Plexiglas of the appropriate thickness could be used to achieve this.)
How I came to this was that I saw someone else build up an old system like this one into a modern case and it actually looked really cool!
Cable management is a real problem with these older systems, so a case such as this one would go a long way to hide all of the ribbon cables and present this motherboard really nicely!
It's a special board, so I think it deserves a special case! (It should present very well through the tempered class window! 😀 )
The only problem is that it's a bit pricy! (So I'll only start to look at this once my current socket 8 build is complete)
My Collection
YouTube
Reply 115 of 152, by H3nrik V!
That is not a case, that is a work of art 🤩
Reply 117 of 152, by BitWrangler
Show stealer sure, but might as well make it look like a Bang & Olufsen stereo because it cost about as much 🤣
Reply 118 of 152, by kixs
Done some testing with my PPRO with 1MB chip running at 233MHz, Windows 95 OSR2, 128MB
Q3A demo, default settings, 800x600:
Voodoo2 12MB ... 28.9 - no sound
Voodoo2 12MB ... 27.3 - low quality sound
Voodoo2 12MB SLI ... 31.5 - no sound
Voodoo2 12MB SLI ... 28.8 - low quality sound
Voodoo 5 5500 PCI... 27.9 - no sound
Reply 119 of 152, by Sphere478
kixs wrote on 2023-01-27, 02:43:
Done some testing with my PPRO with 1MB chip running at 233MHz, Windows 95 OSR2, 128MB […]
Voodoo2 12MB ... 28.8 - low quality sound
Curious, could you do a test audigy 2zs vs isa sound card on this setup? Audigy 2zs is supposed to have a lot of hardware acceleration but idk if basic isa sound might still have the edge? (Performance wise)
Sphere's PCB projects.
