First post, by wise.jo
I've upgraded from Windows 7 Ultimate 64 bit to Windows 10 Pro 64 bit.
Video and audio stuttering in fullscreen under manual config in Windows 10. In Windows 7 it works smoothly in the same computer...
My settings:
fullscreen=true
fullresolution=0x0
windowresolution=0x0
output=overlay
mapperfile=mapper.txt
However it works smoothly in Windows 10 in non-fullscreen mode, even if I change the window resolution to 1728x1080. I have 1080p (1920x1080) 60Hz monitor.
With default settings fullscreen resolution is 640x480 and the height/width ratio is not proportional - both in Windows 10 and 7.
My machine:
Intel Core i5-750 @ 2.67 (stock)
8GB RAM DDR3 1333Mhz Dual-Channel CL9
MSI GTX 750 Ti 2GB GDDR5
GIGABYTE GA-P55-USB3 Motherboard
Kingston A400 SSD 240GB
Can you help?
Thanks
