Mounting multiple CDs
Reply 21 of 35, by DosFreak
Why make more than needed?
Found this in the changelog today:
2006-01-27 08:54 qbix79 […]
* src/dos/dos_mscdex.cpp: increased amount of simultanious cdrom
drives. Makes a few people happy with games that have lot's of
cdroms.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 22 of 35, by HunterZ
I don't care enough to argue, but I just don't see the point in artifical limitations. I can't think of why someone would need to mount more than 10 CD images, but that doesn't mean someone won't come up with a reason at some point.
Reply 23 of 35, by DosFreak
I think Qbix's reasoning which is pretty much how dosbox development works is that they only support what needs to be supported. In this case a user reports that they want to mount a certain # of CD's. So why support something that no one has reported yet?
Examples:
What video mode is used by most DOS game? VGA or VESA modes? Why bother with messing around supporting VESA when the games would work incredibly slow and they have tons of VGA games that need to be fixed.
What sound cards/features need to be support? Some obscure sound card or the soundblaster 16/PC Speaker which most DOS games used.
Also there's the danger of going out of spec of original MS-DOS which may cause problems elsewhere.
Reply 24 of 35, by HunterZ
I thought of the issue of following the original behavior as well; the spec issue it definitely the main thing that should matter. The other examples aren't really the same thing, as this is a case in which the only limitation is a hard-coded number that was determined arbitrarily as far as I know (which also makes me wonder if it could be a dosbox.conf option?)
Reply 25 of 35, by Guest
My thoughts exactly, mate. Why not just simply allow a user to select the maximum number of drives via a dosbox.conf option like this:
MaxCDROMDrives=8
Have the ultimate maximum that the user can select be 24. After all, you need at least drives Z: and C:, thus leaving 24 slots available for CDROM drives (if the user so desires).
I don't know about other users, but I can certainly see myself mounting two-dozen CDs for games that require them. Kind of makes me wonder why I never thought of mounting more than one drive before. [shrugs]
Reply 26 of 35, by DosFreak
Kind of a lame thing to have configurable. Might as well just make it the maximum then instead of having yet another option in DosBox.conf to explain.
Reply 28 of 35, by Roxor
I can see the logic behind the Guest's suggestion of making the maximum number of mountable CDROM drives user-configurable. I'd say that his logic was that by allowing the user to set their own limits on the maximum number of drives that will be emulated would be simply a way for the user to limit the drive-support emulation to what they need.
Now, I don't know how DOSBox's emulation of CDROM drives works, but I suspect that a higher limit on the number of emulated drives would require more CPU power as the program would have to deal with possible extra drives being added. Am I right, or am I off by a long shot with this reasoning?
Reply 29 of 35, by Qbix
Rank DOSBox Author
DOSBox Author
I don't see any need for it.
it doesn't take much cpu power. it does take some memory though
Water flows down the stream
Reply 30 of 35, by Roxor
Out of curiosity, how much CPU power and memory is needed per additional drive?
I know that some users will want to try and milk every last cycle out of their CPU and devote every last byte of memory to their favourite emulator. I do like the Guest's idea of being able to select the maximum number of CDROM drives that can be emulated, though. You could even turn off CDROM support and save on emulating hardware that's not needed by setting the maximum number of CDROM drives to 0 if you don't have any games that need CDROM support to run.
I think it's a nice idea, and probably one that could be implemented fairly easily if you know your way around the DOSBox code. Alas, I don't, and I don't have a C++ compiler for Windows. I only have one for DOS.
Reply 31 of 35, by HunterZ
Qbix said it won't require any CPU cycles to allow more drives, which makes sense. Probably the only difference is that it would (as Qbix said) require more memory to keep track of some things for each drive.
Reply 32 of 35, by avatar_58
This is in context with this thread, so I'll ask here.
For multiple CD games such as Gabriel Knight 2, how would I go about switching the CDs in dosbox? I mean, without having to use daemon tools I can't think of a way. Mounting multiple CDs will only confuse the game, as there is no way to change which letter it looks for. Once it looks to say "D:" for CD1, and then asks for CD2....I can't direct it to "E:" for instance.
Anyone know a way around this?
Reply 33 of 35, by dougdahl
Don't know if it's just my version or not, but when I install GK 2 the resource.cfg has a line at the bottom
CD:=D:;
that allows for additional cd drives.
Unfortunately most other games don't seem to allow this. From the README I've heard that the Ctrl-F4 or alternately the RESCAN command allows re-reading (never used it myself so I can't say).
*My mistake. Re-read the README and that is for disk-images. Sorry*
Also using the -ioctl option might help as when I changed CDs it read the right files with the DIR command without me doing anything (Never tried it playing a game as I don't have my Linux set up with automount, meaning if some file is being accessed while playing a game I can't umount it)
Sorry for getting off-thread.
Reply 34 of 35, by avatar_58
dougdahl wrote:
Don't know if it's just my version or not, but when I install GK 2 the resource.cfg has a line at the bottom CD:=D:; that allows […]
CD:=D:;
Ah silly me, that gave me an idea.
Copy each of the game's CDs into seperate directories and then mount each one with a seperate letter. Then add each letter to that CD:=D line..... 😅
Reply 35 of 35, by dougdahl
Exactly.
Though I only played a little way into the second disc this way. And I used my actual CD # 1 to save hard drive space. Though someone had problems using this method with loading games not from Chapter 1
Gabriel Knight 2 - CD change problem
No idea if it ever got solved, how specific a problem it was, or if a CVS version might help.
