First post, by Bigboes
Hi,
My Notebook has no serial com-port so i use an usb-serial adapter.
Now i've to use an old dos application with this serial interface.
Is there any change to use the usb-serial adapter with DosBox?
Thx
Reply 6 of 7, by Bigboes
yep. But it doesn't work. 😦
Somebody told me that the application i try needs to run under real Dos. 😢
Maybe that's why it'll not work.
But in real Dos there's AFAIK no change to run the USB-Serial adapter. 🙁
Reply 7 of 7, by bgp
But in real dos you will need a real driver that support usd-serial adapter.
I think that is more difficult to find.
Have you tryed another application that uses the serial port, just in case to verify the usb-serial adapter is working ?
Bgp
