DOSBox Game Launcher (DOSBox Frontend)
Reply 1720 of 1731, by rcblanke
Moving on with 0.95 beta2:
  • Prevent crash processing invalid 'scaler' or 'loadfix' settings (GT);
  • Fixed issue when multi-editing and changing 'scaler' or 'priority', resulting in invalid config values. Also display the change correctly in the wizard's confirmation step;
  • Properly grey out checkboxes with conflicting values.
  • Fixed erroneous new-lines in certain GamePackArchive xml fields;
  • Ignore special autoexec features used by D-Fend Reloaded such as 4DOS and DOS32A when importing (dor123);
  • German translation update from Marcel Luka.
All the latest files. To upgrade, just update dbgl.jar.
Ronald
Reply 1722 of 1731, by dor123
It would be good if the profiles file names would have been the names of the profiles in the software rather than numbers, like in the case of D-Fend Reloaded. This could make finding specific profiles easier.
DOSBox 0.74-3
D-Fend Reloaded 1.4.4
DOSBox Game Launcher v0.95beta1
Windows 10 Enterprise 64-bit
Reply 1726 of 1731, by rcblanke
You can easily accomplish this by:
  1. Selecting all profiles (ctrl-a in the profiles list)
  2. Exporting profiles (Profiles -> Export...)
  3. Set [Configuration File] to "Filename by profile title" in File->Preferences (as Neville mentioned)
  4. Re-importing all profiles (that you just exported, Profiles -> Import...)
  5. If the new profiles work correctly, removing the old profiles
Also note that you can easily determine a profile's ID using the 'ID' column in the profile table (I know, amazing), by editing a profile (ID is shown in the editing window between brackets) or opening the captures folder (it ends with the ID). You can also directly open a .conf by right-clicking on a profile and selecting View->Configuration File.
Reply 1727 of 1731, by bloodbat
Hello!
Great work on the launcher, thanks 😀 One thing has been bothering me, since I can't find a way to change it in version 0.94: how do I change the captures folder? Some people may enjoy having a ton of numbered subfolders in a directory. I don't, at all. The numbering scheme is fine for... I don't know, 10 games? More than that and it's painful. I want to dump the few captures I make to the directory where I used to dump them all. Is this at all possible using the GUI or am I doomed to having to edit the .conf file by hand every time I add a game?
Thanks 😀
Reply 1729 of 1731, by bloodbat
rcblanke wrote on 2021-11-11, 17:24:
What would you suggest bloodbat? To use a single directory for all captures? How would DBGL be able to distinguish one profile's captures from another?
Thanks for your reply 😀
I would suggest being able to disable generating all those folders if desired and being able to use one central location for all captures. Make the default as is and, if possible, give the option to use just one folder, much like the "Filename by profile title" which is great.
I understand those folders are also used for covers and such downloaded from internet services, maybe a separate folder for those would be useful for people that use them?
I don't need capture management from the front end: that's what file managers are for and DOSBox names said captures according to whatever is running when they're taken.
Other stuff I've found / suggest:
-There's a display bug for the toolbar under, at least, Windows 10: buttons are cutoff. (Check the attached screenshot).
-Running bootable games is... convoluted to say the least. DOSBox can boot images directly (as stated here: https://www.dosbox.com/wiki/BOOT) yet the frontend insists on mounting the parent folder of the bootable image and then taking some unnecessary detours. I think the games I've managed to convince to boot are either due to sheer luck or by tricking the front end and booting them directly from autoexec.
-Related to the above: while I know most people use the frontend to launch clearly defined games and executables, sometimes I want to do stuff directly from autoexec or launch a command line with certain different options without an specific executable, while it can be done by either tricking the frontend with a fake command, using the Custom Commands stuff tab, or messing directly with the generated .conf, it spews a warning about an "Incomplete profile" when launching or refuses to accept a profile edit. An option to disable this behavior would make the program better, I think. I understand the program aims to be as friendly and useful as possible, and this is done to help a lot of users try and get what they want, but this stuff could be called "Advanced Mode" or something like that.
-I downloaded the program to replace D-Fend Reloaded because it offers the closest behavior I could find and, for the most part, it delivers; however, there's one useful thing missing: the ability to add arbitrary sections and options from the GUI to the configuration files. Sure they can be edited by hand, and, so far, it seems to respect my edits. Why? DOSBox derivatives such as DOSBox-X are in constant flux and offer quite a few options not available in plain DOSBox. D-Fend solved this by offering a simple text box where the user could add whatever they needed and then placing the text before the [autoexec] stuff. This unburdens the frontend programmer from adding every single option (quite a daunting task) to the different "Experimental Options" tabs while allowing the user to use the advanced options to their hearts content without leaving the frontend and having to find and edit the .conf file.
Thanks 😀
    9.13 KiB
Reply 1730 of 1731, by rcblanke
bloodbat wrote on 2021-11-13, 18:04:
Ok, I guess if you don't care too much about the captures, having all these [ID] subdirectories can be unnecessary. I've made this configurable, like you suggest.
I don't see anything wrong with the buttons in your screenshot?! Please note that the last button (for toggling the visibility of a profile's notes) might not be the best design, though. If anyone can come up with a better one in 16x16, I'm all for it.
I kindly disagree. Although I cannot remember exactly why I opted for the 'mount dir first, boot afterwards' route (instead of booting directly) back in 2006, I'm pretty sure there was a reason for that. Anyway, I don't see what is so 'convoluted' here:
  1. Click 'Add profile'
  2. Type title and click the 'Mounting' tab;
  3. Click on the 'Booter' expand-bar;
  4. Click 'Browse' next to the 'Image 1' field and select your booter image. The parent directory is added automatically in the mounting overview;
  5. Click 'Ok' to save the profile.
Maybe you've stumbled upon a bug? Or you didn't use image filenames conforming to the DOS 8.3 short filename standard? That will likely lead to a broken profile. Anyway, I've added a warning when trying to use non-8.3 filenames to hopefully prevent such issues.
This suggestion has come up a couple of times before. Unfortunately, due to technical reasons this request is currently unfeasible. In DBGL's codebase, a profile is more or less defined as consisting of a set of meta-data in conjunction with a DOSBox configuration with a target runnable. Although I might come up with a real solution in the future, for the moment the best thing to do is simply to enter a bogus executable in 'Main' (like A.EXE, you can enter anything as long as it ends with .com/.exe/.bat). Remember that you can right-click on a profile and 'Start manually' to prevent execution of the 'Main' executable (and bypass 'exit') so you can test things in DOSBox.
Running 'stuff' directly from autoexec can be easily accomplished using the 'Custom commands' tab.
... the ability to add arbitrary sections and options from the GUI to the configuration files.
Good idea, implemented. You can find the feature in the 'Custom commands' -> 'DOSBox custom section' tab.
0.95 beta3:
  • Implemented custom conf sections for templates and profiles (bloodbat)
  • Display warning when using non 8.3 filenames, use double quotes around booter image filenames when they contain a space (bloodbat);
  • Allow for choosing to have all captures in single folder (bloodbat)
  • Try to improve layout issue with filled text fields (GT);
  • Fixed pouet querying (changes on the website regarding demo scoring).
Ronald
Reply 1731 of 1731, by bloodbat
rcblanke wrote on 2021-11-22, 08:10:
Ok, I guess if you don't care too much about the captures, having all these [ID] subdirectories can be unnecessary. I've made th […]
0.95 beta3:
Ronald
Thanks a lot for the changes, fixes and explanations 😀
I understand the button that looks cut in half is meant to look like that; but I found a problem in the preferences: the "Port" text box won't display even a single number in full (out of what seem to be 4); I attached a screenshot.
13.19 KiB
