Reply 1780 of 1791, by Neville
- Oldbie
Is there more people affected by this bug?
You're the only one as of yet, but then again, you may also be one of the very few users actually trying out the beta builds 😜
rcblanke wrote on 2022-04-28, 19:31:You're the only one as of yet, but then again, you may also be one of the very few users actually trying out the beta builds 😜
Well to be honest, the need of installing a full jdk 11 pulled me back (as mentioned I have DBGL installed in a Cloud Drive and I use it in different machines, some of them older).
Nevertheless I did install the latest Beta you released after my enquiry, and I can confirm that the links are working as intended in 0.96beta4, I tried succesfully with:
Media (cover art, screenshots, etc.) are also downloaded as jpg as intended, resulting in a much appreciated room-saving of cloud storage.
Wouldn't want to ask for too much but... would you be able to generate a scaled-down runtime environment with the java modules required for DBGL using jlink? Maybe as an extra download on DBGL website.
I forgot to mention another issue I've been experiencing with DBGL. I may have mentioned before that I have several DBGL installations on my PC. One for playing, and another to test new games / apps I come across. This later install is the only one where I use DBGL betas.
But I've also got another installation of DBGL, this one in my D: drive. Here I keep each and every single one of the DOS games / apps I've ever seen. Some of them require DOSBox-X, which works fine on my other installs. But here for some reason I can't run it. It keeps showing this error message:
Is this a bug or I forgot to do something to get DOSBox-X working?
Don't know why your getting that windib error, but that seems to be an sdl videodriver. From what I found, is that for an SDL1 program directx is the default SDL_VIDEODRIVER, while for an SDL2 version the only option appears to be SDL_VIDEODRIVER=windows
https://wiki.libsdl.org/FAQUsingSDL
Since this seems to be exclusive to SDL1, apparently your using the SDL1 version of DOSBox-X. Does the SDL2 version work?
Actually, I'm using the x64 SDL2 build. And it works from D: outside of DBGL.
Between this and the links issue, I'm starting to think my system is cursed xD
Is it possible that DBGL is setting the SDL_VIDEODRIVER= environment setting on windows that is causing problems, as SDL_VIDEODRIVER=windib does not appear to be valid for SDL2?
Neville wrote on 2022-05-01, 20:14:I forgot to mention another issue I've been experiencing with DBGL. I may have mentioned before that I have several DBGL install […]
You might have customized your dosbox environment like this:
If so, disable the customization (un-tick) and try again!
That was it! I remember adding that modification years ago, but I can't remember why.
Problem solved, then.
Both dgbl 095 and 096beta5 can't seem to find my installation of temurin jre 11 (x64). I'm on windows and used chocolatey to install jre 11.
Edit: My bad, I didn't realize I had to start dbgl via dbgl.cmd and not launch.exe
The new Links option has made me realise there a few settings / messages that still don't have a Spanish translation. rcblanke, could you PM just the untranslated stuff so I can update the translation? Thank you.
It's just lines 844 to 847, Neville.
RedTony wrote on 2022-04-30, 07:19:Would you be able to generate a scaled-down runtime environment with the java modules required for DBGL using jlink? Maybe as an extra download on DBGL website.
Yep, coming soon.
