D.O.G. Developments
Reply 20 of 22, by ErikGG
Thanks wd,
But i'm not talking about reprogramming DosBox, but externally, letting D.O.G. detect the execution line.
Because currently I search for the DosBox "SDL Form" off class "SDL_app" and ask the Window's position, center the mouse on it and simulate a click. This is executed afther a certain time, but during this time D.O.G. is in sleep mode, doing nothing at all, not even processing messages what in Windows results in a 'Hanging' application. If I could detect the call to the executable then I could make the clicking snappier and faster.
Erik.
Reply 21 of 22, by wd
Rank DOSBox Author
DOSBox Author
Don't know if that's possible. You might add some line right before the
executable is started like "echo x >loaded.dat" and check for that file.
Sounds clumsy to me though.
But i neither see any problem with klicking on the window or using the
lockfree mouse.
