First post, by rcblanke
Hi all,
Challenge: I have a collection of games and .conf files which I have set up for a particular Windows pc using an USB HDD. These can be used just as easily on another Wintel machine, as long as I make sure that the drive letter for the USB disk is the same. However, a couple of games require Munt for MT-32 emulation, using "[midi] config=1" since the Munt device driver is being enumerated as midi device no. 1 in Windows. Unfortunately, on the second machine, Munt is 'windentified' as midi device no. 2, making all MT-32 games sound like crap.
Question: How to set up the two computers so that Munt is correctly being used where appropriate?! I cannot find a way to change the order in which Windows midi devices are enumarated. Does anybody? A specific tool maybe?
Another way to solve the issue might be to have DOSBox select a midi device not only by ID, but also by name (config=MT-32 Synth Emulator or something similar). I might even try to write a patch for that myself, but I kindly have to ask for a little help in that case. Can anybody point me in the right direction? Thank you!
Regards,
Ronald
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
you might be able to do it with a bat file inside dosbox or a small executable.
I don't have a clue on how to change the enumaration inside windows.
Water flows down the stream
Reply 2 of 2, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
AFAIK everytime you select a different midi device as default in the audio settings of the control panel the enumeration gets shuffled. It's probably a trial and error until you have the munt device on both PCs in the same "slot".
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
