First post, by jalal
Hello all,
Is there a way to run a dos game using DosBox in Black and White colors?
Thanks,
Jalal
Hello all,
Thanks,
Jalal
I don't think so but maybe you could achieve that desired effect running a CVS version capable of running using D3D and applying some grayscale effect from your video card control panel.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
ok it worked:
Just change machine type (in dosbox.conf) to:
machine=hercules
but the screen is wide and the movement are longer ...
Yes. That's another way, but keep in mind that most games won't support Hercules at all.
Intel i7 5960X
8 GB DDR4 (2100)
